RN4220
4 TopicsReadyNAS RN4220 wont boot up after shutdown from WebUI
Hello to anybody who can help, I got a ReadyNAS RN4220 out of eWaste from some company, and it worked perfectly! I have 100tb of NAS HDD storage in it and it has run fine for over a year now. Last week i decided to shut down my home rack gracefully just to give it a breather in the Australia summer heat. For the RN4220 i shut it down by using the Web Interface, telling it to turn off. It did so fine. A few days later, i tried turning it back on. It spins the fans to the highest settings and does not turn on. I have tried leaving it for a few hours overnight (approx. 8) to no avail. Does not even show up on RAIDar. What happens is it just sits there with the power LED blinking green and the network lights blinking green with fans on highest. If i force turn it off by holding down the power button the Red Health LED blinks once then goes away and the power LED goes back to amber as per normal. Again nothing has changed with the setup aside from me just shutting it down from the Web UI and turning it back on. I have done so in the past no issues. No clue whats changed. Here are some of the debugging steps i have tried: I cannot do an OS reinstall or Factory Reset as holding down the reset button for a minute on boot does not change the LEDs at all (as shown in the Hardware user manual, -> https://www.downloads.netgear.com/files/GDC/RN2120/ReadyNAS_OS6_Rackmount_HWM_EN.pdf the power LED, UI LED and Health LED should all be blinking, only the power LED blinks, assume it just isnt taking the reset command for some reason) Taking out all the disks and network cables and trying to boot up, no change Taking out all but 1 disk and booting up, no change I have tried removing both power cables (Its powered by wall power, not a UPS) and leaving it off overnight fully power cycling. no change. I have tried using the serial port on the back with a USB RS232 cable, a null modem cable (as its female port and i needed male-male) and Putty on a windows machine. Nothings happening on the console. Tried a few different baud rates to no avail. I have tried taking the top off, reseating the RAM and a few cables (Not all as im unsure what most of them do and they are quite tight in there) no change. I have tried taking out the CMOS battery from the Mobo and powering off the machine (unplugging) for a few hours. No change. I have tried running with just 1 of the PDUs on the back, it runs a red LED on the health indicator but otherwise no change. Please let me know if any additional info or photos can be useful for fixing this. I know its an older unit (if there are any newer replacements i could just take my drives and plug into with atleast 12 bays let me know, pref rack mount, and i can also look into that). I heard you can just swap drives between READYNAS products and they should work fine yeah? In terms of firmware on the device i think i installed the latest some time last year when i got it. But i cant access it to get the info anymore. I just am so confused why a simple reboot (done through the web UI!!!) would cause it to never boot up again.... Thanks for your time.912Views0likes9CommentsFirmware Update RN4220 from 6.6.1 -> 6.7.4
I have an RN4220 with an iSCSI LUN that we use as a backup destination for our network. It's fully populated with 4TB WD Enterprise drives. I've been nagged with the "Firmware update available 6.6.1 -> 6.7.4" screen for a while, and had an opportunity to take down the backup server so I could firmware update the RN4220. 45 minutes ago, I clicked the Update button on the web console. It downloaded, said it needed to do a reboot. Pings dropped off, and it's not come back online since that point in time. The power light is flashing green, no other disk activity is evident. Next step? Never had to troubleshoot this thing before...2.7KViews0likes2CommentsRN4220 Red Error light on
Hi, suddently in my readynas RN4220 Red LED notification is always ON, i could not find the reason why the RED notification light is on. I have checked in the system console for any errors, logs and everything looks fine. All my redundant power supply is connected, using X raid, all the HDDs are green. Is there any way to find the issue behind the Red LED indication? Thanks.Swapping Network Card - 10GbE for CX4
I have a ReadyNAS 4220 that came with a dual port 10 Gigabit Ethernet card, I need to replace it with the CX4 add-on card. I've replaced the card, but I am not seeing the ports in ifconfig nor the frontview interface. I guess I need to update the kernel or install the ixgbe driver? I'm savvy to compiling kernels and modules for Linux, but I am not clear on where to obtain the headers, since there aren't any provided when using the linux-headers-`uname -a` trick, Linux SERVER 3.0.101.RNx86_64.3 #1 SMP Thu Dec 18 18:35:16 PST 2014 x86_64 GNU/Linux If I upgrade to the latest version of ReadyNAS OS will the driver compile automatically? I feel like it's sort of crazy that with so few addon card options, they all aren't included with the OS.. Thank you!Solved
