Raidar can not find
1 TopicHelp ReadyNas Duo v1 - Unable to connect after power down
Hi, Since powering down my Nas (2 seagate disks - dont think I set up RAID) for about a week, I have no longer been able to connect to it, or find iton my network usjng RAIDar. I have checked network cables and everything seems ok. I tried a OS instal, as that has resolved similar issues I have had in the past. This didnt work. I then tried connecting by linking the Nas directly to my PC (after setting the pcs ip address and subnet to thatof the default Nas), but this failed to work. The Nas itself shows not unusual led blinking after appearing to boot normally. The ethernet plug socket suggests its connected as both lights are on solid. I have connected to my router, which shows the nas is not connected to the network/router. I want to keep the data on the Nas so I havent tried a factory reset. Yesterday I tried flashjng the OS using a usb with the latest firmware image (raidar 4.1.14). During this process the led showed an error code; 3 blinks, which I think is bad contents on root partition.I have since shuf down and restarted. Its now still not accessible, but not showing error codes. Help, I dont know what else to try!Solved3.5KViews0likes10Comments
