ReadyNAS 316
3 TopicsCant enable SMB on ReadyNas 316
Hi, I noticed that SMB service on my ReadyNas 316 with version 6.9.3 stopped working 2 days ago and I can't turn it on. At first I didnt see the shares and after reboot, I saw that SMB was turned off. I have tried to search for any solutions but I cant find one. I really don't want to do an factory reset. What I tried so far: OS Reinstall Downgrade from: 6.9.3 -> 6.9.1 -> 6.9.0 -> 6.8.1 and then back to 6.9.3 = None version is working Update pagages with "apt upgrade" When I run "systemctl status -a smb": root@NAS:~# systemctl status -a smb smb.service - Samba SMB Daemon Loaded: loaded (/lib/systemd/system/smb.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Sat 2018-04-28 13:18:04 CEST; 49s ago Process: 8988 ExecStart=/usr/sbin/smbd --foreground --no-process-group $SMBDOPTIONS (code=exited, status=1/FAILURE) Main PID: 8988 (code=exited, status=1/FAILURE) Apr 28 13:18:03 NAS systemd[1]: Starting Samba SMB Daemon... Apr 28 13:18:04 NAS systemd[1]: smb.service: Main process exited, code=exited, status=1/FAILURE Apr 28 13:18:04 NAS systemd[1]: Failed to start Samba SMB Daemon. Apr 28 13:18:04 NAS systemd[1]: smb.service: Unit entered failed state. Apr 28 13:18:04 NAS systemd[1]: smb.service: Failed with result 'exit-code'. When I try to manually start smb.service I get: root@NAS:~# systemctl start smb Job for smb.service failed because the control process exited with error code. See "systemctl status smb.service" and "journalctl -xe" for details. I find following in journalctl -xe: Apr 28 13:14:57 NAS systemd[1]: Starting Samba NMB Daemon... -- Subject: Unit nmb.service has begun start-up -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit nmb.service has begun starting up. Apr 28 13:14:58 NAS systemd[1]: nmb.service: Main process exited, code=exited, status=1/FAILURE Apr 28 13:14:58 NAS systemd[1]: Failed to start Samba NMB Daemon. -- Subject: Unit nmb.service has failed -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit nmb.service has failed. -- -- The result is failed. Apr 28 13:14:58 NAS systemd[1]: nmb.service: Unit entered failed state. Apr 28 13:14:58 NAS systemd[1]: nmb.service: Failed with result 'exit-code'. Apr 28 13:15:09 NAS readynasd[3398]: Service 'nmb.service' goto unexpected state 'failed'. Expect to be 'active'('activating'). Apr 28 13:15:09 NAS readynasd[3398]: Protocol 'cifs' is reloaded Apr 28 13:15:09 NAS systemd[1]: Starting Samba NMB Daemon... -- Subject: Unit nmb.service has begun start-up -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit nmb.service has begun starting up. Apr 28 13:15:09 NAS systemd[1]: Started WSD/LLMNR Discovery/Name Service Daemon. -- Subject: Unit wsdd2.service has finished start-up -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit wsdd2.service has finished starting up. -- -- The start-up result is done. Apr 28 13:15:09 NAS wsdd2[8270]: starting. Apr 28 13:15:09 NAS systemd[1]: nmb.service: Main process exited, code=exited, status=1/FAILURE Apr 28 13:15:09 NAS systemd[1]: Failed to start Samba NMB Daemon. -- Subject: Unit nmb.service has failed -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit nmb.service has failed. -- -- The result is failed. Apr 28 13:15:09 NAS systemd[1]: nmb.service: Unit entered failed state. Apr 28 13:15:09 NAS systemd[1]: nmb.service: Failed with result 'exit-code'. Apr 28 13:15:09 NAS systemd[1]: Starting Samba SMB Daemon... -- Subject: Unit smb.service has begun start-up -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit smb.service has begun starting up. Apr 28 13:15:09 NAS wsdd2[8270]: cannot read workgroup from testparm Apr 28 13:15:09 NAS wsdd2[8270]: cannot read workgroup from testparm Apr 28 13:15:09 NAS wsdd2[8270]: cannot read netbios name from testparm Apr 28 13:15:09 NAS wsdd2[8270]: cannot read netbios name from testparm Apr 28 13:15:09 NAS systemd[1]: smb.service: Main process exited, code=exited, status=1/FAILURE Apr 28 13:15:09 NAS systemd[1]: Failed to start Samba SMB Daemon. -- Subject: Unit smb.service has failed -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel -- -- Unit smb.service has failed. -- -- The result is failed. Apr 28 13:15:09 NAS systemd[1]: smb.service: Unit entered failed state. Apr 28 13:15:09 NAS systemd[1]: smb.service: Failed with result 'exit-code'. Apr 28 13:15:09 NAS wsdd2[8270]: Terminated received. Apr 28 13:15:09 NAS wsdd2[8270]: Terminated received. Apr 28 13:15:09 NAS systemd[1]: Stopping WSD/LLMNR Discovery/Name Service Daemon... -- Subject: Unit wsdd2.service has begun shutting down -- Defined-By: systemd -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel Can someone please help me?Solved2.1KViews0likes2CommentsReadyNAS 316 File transfer through Windows 10
I always use Windows Explorer in Windows 10 to transfer files for my desktop to the NAS. Everything was fine up until two weeks ago. The transfers continue flawlessly. When there is an exact copy of a file transfering from my laptop to the NAS Windows Explorer there are two choices. Keep the file in the NAS or replace it with the file coming in from the computer. Pretty easy stuff. What happens is that after clicking and giving the command to replace the file in the NAS with the file coming in from my laptop the transfer slows down rapidly and stops. I would have to go into the NAS and delete the file and then transfer the duplicate file coming in from the laptop. Can anybody help me with this please? I wold greatly appreciate it! Thank you! Raphael Torres2.3KViews0likes2CommentsRN316 randomly freezing shared folder on 6.4.0
Hi, I upgraded a client's RN316 to firmware 6.4.0 about 2 days ago. The firmware update reported successful and all seemed ok for about half a day. Now the primary share (2.7TB) of data, has become extremely unstable, randomly freezing up for about 10 minutes when PC's or Macs try to access it. Protocols enabled are SMB, AFP and NFS, and permissions are open - everyone can read/write. The unit has 2 x 4TB hard drives running (mirrored). Approx. 25-30 users may be accessing the share at any one time, and this was fine on 6.2.4. I had hourly snapshots running, but have reduced them to daily to try troubleshoot - the issue persists. I have tried using the 2nd NIC instead (Gb LAN), changed the device IP address, really just about exhausted all I can think of. Is there any way to rollback to 6.2.4? Will resetting permissions maybe help, or switching off and re-enabling protocols for the relevant share...? Thanks guys, I'm at a loss here. A great product being let down by these bugs right now :(Solved12KViews1like22Comments
