ReadyNAS NV+ V1
2 TopicsWhere did my Recycle Bin go?
I accidently deleted a file and went looking for the Recycle Bin to restore it. I am pretty sure I've seen a Recycle Bin associated with my User account, but it was nowhere to be found. I have the Recycle Bin enabled in the Security > User Group > Preferences, but have no idea where it is. Model: RNRNV2-S2-0000 Processor: IT3107 Sparc RAIDiator 4.1.16Solved7.4KViews0likes5CommentsGarbled NV+ display after Nv+ turned on
Hi, i have a ReadyNAS NV+ V1 that's been disconnected from power for 2 months while we moved. When I finally got the NV+ plugged in and connected to my router, thy familiar "Booting...." Line comes up first. But when it continues booting, the LED display started generating random characters on the whole screen. When the boot process is over the display goes blank as usual. Looking thru RAIDar, the drive is fine with all the drives at green (I don't see the UPS monitor in RAIDar, but I have the connections for it). The NV+ ran all night, but the morning showed the same gobbliygook on the LED display. Does anyone have info on why this is happening? Will it lead to more disastrous problems? Is there a way to fix it? Thanks....Mike3.2KViews0likes6Comments
