ReadyNAS Pro
2 TopicsShares show no folders but there is a lot data on the disc
Hi I have a Ready NASPro2 with firmware 4.2.28. Logging on to it and then cheking Volume settings it shows 902 GB used of 913 GB (98%). But when connecting to shares such as backup or media on my Windows laptop. There is nothing there. Also when in Windows Explorer right clicking on the drive and chose propertiees It shows the same size... But I cant access or see anything. Any one have some idea how to access the data...? Thanks in advance //H2KViews0likes1CommentIt is possible to disable the auto boot on Power on for ReadyNAS Pro (6) OS 6.4.1?
I have a legacy ReadyNAS Pro and a ReadyNAS Pro 6 (RNDP6000-V2) Both are running 6.4.1 Both have BIOS 07/26/2010 FLAME6-MB V2.0 Unfortunately both automatically boot on mains power on. I really would prefer them to be manually powered on with the button on the front *after* the mains is applied. I've looked through the BIOS. No suitable options in there. Is this indeed possible? Spike2.8KViews0likes2Comments
