ReadyNAS Ultra|Pro|NVX
21 TopicsPHPMyAdmin
PHPMyAdmin Description: Administrate your Mysql database from a browser. phpMyAdmin is a free software tool written in PHP intended to handle the administration of MySQL over the World Wide Web. phpMyAdmin supports a wide range of operations with MySQL. The most frequently used operations are supported by the user interface (managing databases, tables, fields, relations, indexes, users, permissions, etc), while you still have the ability to directly execute any SQL statement. Requirements: RAIDiator 4.2.1+ and PHP Addon for the PRO Platform: PRO/NVX Current Version: 2.5 PRO PHPMy Admin (12/15/2010) PRO PHPMy Admin (02/11/2010) solve a bug when add-on is disable (notice it takes time to re-enable it) no more needs to reboot after installing this version updated to the last multinlanguage version : 3.3.8.1 PHPMyadmin can now be disabled User is admin with your admin password Installation Notes: you need to install PHP addon if not already done Screenshots: Old Versions: Removed Credits and Sources PHPMyAdmin Web SitePHP5 (currently 5.2.17)
PHP5 5.2.17 Description: PHPis a widely-used general-purpose scripting language that is especially suited for Web development and can be embedded into HTML. Requirements: RAIDiator 4.2.15 Platform: Intel Current Version: PHP5_5.2.17-rnx86-1.4.6.bin Changes from previous release: - Fixed compile time bug in recode library so it now works on the NVX again (thanks to gpnas for reporting and lending his NVX for testing ;)) Important: Make sure to have SSH access enabled on your ReadyNAS before installing this addon. (Better safe than sorry!) This module is not compatible with the PHP addon from super-poussin. If you already installed his version, do not install this PHP addon! You have been warned. This module should be compatible with the SqueezeBox-Addon. I tried with the latest version and it worked for me. If you encounter problems, let me know No restart of the ReadyNAS required, should work right after installation. Give it a minute or two for the web server needs to restart in the background. (Now really ;)) This addon is compiled with optimized compiler flags for the CPUs used in the Intel based ReadyNAS systems. New: Allows to enable / disable certain modules from within FrontView. Example: Details: This addon contains the libphp5.so module for the Apache web server as well as the command line version of PHP. Included are the following extensions: - PEAR - bcmath - bz2 - calendar - ctype - curl - date - dba - dom - eAccelerator (*NEW*) - exif - filter - ftp - gd - gettext - hash - iconv - imap (REMOVED in 5.2.17) - ldap - json - ldap - libxml - mbstring - mcrypt - mhash - mime_magic - mysql - mysqli (*New*) - odbc - openssl - pcre - PDO - pdo_mysql - pdo_odbc - pdo_sqlite - posix - Reflection - session - shmop - SimpleXML - snmp - soap - sockets - SPL - SQLite - standard - sysvmsg - sysvsem - sysvshm - tidy - tokenizer - wddx - xml - xmlreader - xmlrpc - xmlwriter - xsl - zip - zlib History PHP_5.2.17-rnx86-1.4.5.bin - Update PHP to 5.2.17 - now with all libraries the modules depend on ... - Make MySQLi module really work (finally) PHP_5.2.17-rnx86-1.4.4.bin - Re-enabled MySQLi extension yet again - Made Apache cleanly restart after Add-on installation - Contains the php.ini fixes for large uploads - Added incompatibility note with Super-Poussins PHP add-on. - Other changes: see Official Changelog PHP_5.2.14-rnx86-1.1.2.bin - Re-enabled MySQLi extension - Made Apache cleanly restart after Add-on installation - Fix for enabling / disabling the whole Add-on (thanks to Sphardy) - Contains the php.ini fixes for large uploads - Added incompatibility note with Super-Poussins PHP add-on. - Other changes: see Official Changelog PHP_5.2.13-readypro-1.0.1.bin - Removed MySQLi extension for it was causing intermittent Apache hangs (ie. Apache didn't restart) - Now allows enabling / disabling of modules through Frontview - Other changes: see Official Changelog PHP5_5.2.12-readypro-0.9.0.bin Security Fixes - Fixed a safe_mode bypass in tempnam() identified by Grzegorz Stachowiak. (Rasmus) - Fixed a open_basedir bypass in posix_mkfifo() identified by Grzegorz Stachowiak. (Rasmus) - Added "max_file_uploads" INI directive, which can be set to limit the number of file uploads per-request to 20 by default, to prevent possible DOS via temporary file exhaustion. (Ilia) - Added protection for $_SESSION from interrupt corruption and improved "session.save_path" check, identified by Stefan Esser. (Stas) - Fixed bug #49785 (insufficient input string validation of htmlspecialchars()). (Moriyoshi, hello at iwamot dot com) - Other changes: See the Official Changelog PHP5_5.2.11-readypro-0.9.6.bin: - First release Donations: If you like this addon, please donate.AirVideo Server Linux
AirVideo Server Description: Video Streaming Air Video can stream videos in almost any format to your iPhone, iPad and iPod touch. You don't need to copy your videos to the device just to watch them. Live Conversion If the videos in your collection are not in format supported by iPhone or iPad, Air Video will convert them on fly*. You don't need to wait until the entire video is converted. You can start watching it almost immediately! Live Conversion requires iPhone or iPod touch with firmware 3.0 and a sufficiently powerful computer (Intel Core 2 duo or equivalent processor is recommended). Requirements: RAIDiator 4.2.15+ Platform: x86 - 64 Bits Version (this means it will not work currently on the NVX/2100) Current Version: 1.0/1.0.1/1.8.00/2.0.00 (1.8.00 with ffmpeg 1.0 will work on all X86 Readynas) Airvideo 1.0 (everything downloaded from internet (12/30/10) AirVideo 1.0 All in one (12/30/10) AirVideo 1.1 update with password Protection (123456789) (12/30/10) AirVideo 1.8.00 update with password Protection (123456789) (03/17/11) please install ffmpeg for Airvideo 1.8.00 AirVideo 2.0.0 aka Alpha 6 (05/10/11) please install ffmpeg for Airvideo 2.0.00 AirVideo 2.4.63 aka 2.4.6 beta 3 (07/30/2012) Based on AirVideo Server Alpha 6 for linux Thanks To Chirpa for the great work done on AirVideo Password and path are stored in /c/webroot/AirVideo/readynas.properties. Installation Notes: Simply Install it and also install air video client on your iphone http://itunes.apple.com/WebObjects/MZSt ... 50020&mt=8 Screenshots: Go There Old Versions: Credits and Sources : Air Video Web SiteSickBeard (x86)
SickBeard AlphaMaster Description: SickBeard is a PVR for newsgroup users (with limited torrent support). It watches for new episodes of your favorite shows and when they are posted it downloads them, sorts and renames them, and optionally generates metadata for them. It currently supports NZBs.org, NZBMatrix, NZBs'R'Us, Bin-Req.com, Newzbin, NZB.su, and EZRSS and retrieves show information from theTVDB.com and TVRage.com. Requirements: RAIDiator 4.2.10+ (may work with earlier versions but that's untested) For this add-on to work,the Python2.6 add-on has to be installed on your ReadyNAS. If you want to integrate SickBeard with SABnzbd make sure to install SABnzbd FIRST. SickBeard will then pick up the necessary settings automatically. Platform: Intel Current Version: SickBeard 0.485.1 v0.8.1 Changes in this release: Updated to the latest SickBeard release Now allows to be updated over the internet directly on the ReadyNAS Details/Installation: After installation of the add-on, SickBeard is already running. It's web interface can be accessed by typing http://<ip of your NAS>:8888/ in your browser's address field. Or you visit the add-on section in FrontView via "Services -> Installed Add-ons". In the SickBeard section you'll find a link called "Manage Sickbeard". Clicking on it will automatically send you to SickBeard's main screen. The first action should be to verify the settings under the "Config" section. If you followed the advice given above and installed SABnzbd first then all settings to integrate SickBeard with SABnzbd should already be present. It never hurts to double-check, though. Also you should check the search engine settings and adapt as needed. A nice SickBeard configuration guide for the rest of the various settings can be found on Ainer.org.SaneBackends 1.0.22 (Scanner Access Now Easy)
sane-backends 1.0.22 Description: SANE stands for "Scanner Access Now Easy" and is an application programming interface (API) that provides standardized access to any raster image scanner hardware (flatbed scanner, hand-held scanner, video- and still-cameras, frame-grabbers, etc.). (...) If you're familiar with TWAIN, you may wonder why there is a need for SANE. Simply put, TWAIN does not separate the user-interface from the driver of a device. This makes it (...) impossible, to provide network transparent access to image acquisition devices (which is useful if you have a LAN full of machines, but scanners connected to only one or two machines). In contrast, (...) SANE has no difficulty supporting command-line driven interfaces or network-transparent scanning. Bluntly put: With SANE you can connect your scanner to your ReadyNAS and scan from every workstation you like - as long as there's a SANE frontend available for your client's operating system. Requirements: RAIDiator 4.2.x Platform: Intel Current Version: SaneBackends 1.0.22 Changes from previous release: - New backends: kodak (Kodak i18xx), kvs1025 (Panasonic KV-S10xx), p5 (Primax PagePartner) - 224 more scanner models supported. - Many backends updated. - Improved saned network daemon. - Internal SCSI, USB, threading, TCP & UDP code updates. - New sanei_magic image processing library. Details: This addon adds the SANE backend drivers for many scanners to your ReadyNAS Of course, only USB scanners are supported ;) To make use of a scanner attached to your ReadyNAS, you need a SANE frontend A good frontend would be XSane, which is available for Linux and Windows Drivers included: abaton agfafocus apple artec artec_eplus48u as6e avision bh canon canon630u canon_dr cardscan coolscan coolscan2 coolscan3 dc25 dc210 dc240 dmc epjitsu epson epson2 fujitsu genesys gt68xx hp hp3500 hp3900 hp4200 hp5400 hp5590 hpljm1005 hs2p ibm leo lexmark ma1509 matsushita microtek microtek2 mustek mustek_usb mustek_usb2 nec net niash pie pixma plustek plustek_pp qcam ricoh rts8891 s9036 sceptre sharp sm3600 sm3840 snapscan sp15c st400 stv680 tamarack teco1 teco2 teco3 test u12 umax umax_pp umax1220u xerox_mfp A little XSane tutorial Let's say your ReadyNAS has the IP address 192.168.10.123 and there's a supported scanner attached it. To make XSane (Windows and Linux version) see your scanner, all you have to do is to edit the file net.conf. Under Windows, this file will be located in the directory sane/etc/sane.d/ below the folder where you unzipped the XSane-Win archive. On Linux, this file normally is located in /etc/sane.d/. All you have to do is to add a single line, containing the IP address of your SANE-enabled ReadyNAS - so in this case this would be 192.168.10.123. Afterwards, you can do stuff like this: XSane scanning for available devices: XSane actually found the scanner attached to my ReadyNAS DUO: So let's do a preview of what's on the scanner right now: Ok, we just want the CD cover, not everything: Scan in progress, receiving data: Ok, I had to reduce that image a bit so it'll somehow fit in here (Original size of that screenshot is 1920x1080): Version History: 1.0.20-readypro-0.1.2 - Fixed a whitespace bug in the addon's JavaScript 1.0.20-readypro-0.1.0 - First public release Donations: If you like this addon, please donate.LLINK 3.0
LLINK Description: Media Streamer for Syabas Platform Requirements: RAIDiator 4.2.3+ Platform: PRO/NVX Current Version:3.0 Llink 2.2.2 (11/04/10) Llink (01/18/09) based on llink 2.2.2 correct skin location problem you can know modify the llink.conf without ssh access (llink.conf is under webroot/llink/ share) Added UDF2.50 support to dvdread for BD-5 ISO images. (HD-DVD as well, in theory) Added support to UDF list files (instead of just domain,title DVD lookup) Jukebox page 2 and up incorrectly handled Separator for files. libdvdnav fails to open paths with /VIDEO_TS/. Reverted function from libdvdread. Changed pass=0 to list and cache only. Pass=1+ simply replays cache. No need for lastline etc. Fix history code so parent sets from page and focus correctly. Fix focus setting Add user-set sort-types in conf Add sort-by cgi key, and MACROS to control sorting. Fixed SSDP to also work against xbox360 and Playstation3 (query only, more work needed for actual use) Added option to automatically expand RAR files when listing. Added option to automatically expand ISO files when listing. Added option to allow sending of index.html file if present in directory New MACROs for current page, tvid-tvid and total pages, total files. Minor changes in extra-info, directory.ext was terminated at .ext Installation Notes: none Screenshots: Old Versions: initial release Credits and sources : LLinkTonido
Tonido Description:Cloud software with a lot of application. Tonido allows you to access and share your content directly through a web browser without uploading or worrying about storage limits. Share files, music, photos and calendar, download torrents and even manage your finances straight from your desktop. Requirements: RAIDiator 4.2.12+ Platform: X86 Current Version: 1.2 Tonido for Readynas (08/28/10) User of 1.0 version no need to upgrade to 1.1 , 1.1 solve only an installation bug for some people so if Tonido is working no need to upgrade User of 1.1 you can update directly from Tonido wen interface :) v 2.10.0.12241 - Aug 19, 2010 - General: Tonido now supports video playback in explorer - General: Tonido now supports audio playback in explorer - General: Multi-file Flash Uploader - Torrent: New Torrent UI - General: Thumbnails of photos now in explorer - Workspace: Guest Access - Webshare: Switch between list and gallery view - Remote: Allow File Deletion from Remote location Integrated web server. Bittorent Client. Powerful apps: Share large files, Listen to and share your music, Publish a blog, Manage your finances and more. Your data is stored locally in open formats and always stays with you Extensible: Allows new Tonido apps to be installed on the fly as they become available. Access your desktop using a custom URL without any network configuration. (username.tonidoid.com). Access your data and Tonido applications from an iPhone or any device with a web browser. Thots is an application for Tonido that acts as a private blog or journal, which you can use to store notes, bookmarks, Web Clips, and other random pieces of information. If you like WordPress, you will love Thots.. ..... Installation Notes: Simply use frontview to install it and click on the interface button Usage go to http://nasip:10001 Please note tonido is runing as user tonido so please do not delete the tonido user If you remove the addon then install it again , you will be forced to create a new user (it's a tonido restriction not my fault) so you can backup /home/tonido if you want to reuse the same account To have better performance disable torrent client if you do not use it Screenshots: Old Versions: Tonido for Readynas (08/04/10) Tonido for Readynas (08/03/10) Credits and Sources : Tonido web sitePHPLogCon - Loganalyzer
PHPLogcon Description: see your syslog message. phpLogCon is a web interface to syslog and other network event data. It provides easy browsing and some basic analysis of realtime network events. Depending on the applications feeding the database, it can process syslog messages, Windows event log entries and even SNMP trap data - just to name a few. phpLogCon is part of Adiscon's MonitorWare line of monitoring applications. It runs both under Windows and Unix/Linux. The database can be populated by MonitorWare Agent, WinSyslog or EventReporter on the Windows side and by rsyslog on the Unix/Linux side. phpLogCon itself is free, GPLed software (as are some other memebers of the product line Requirements: RAIDiator 4.2.13+ and PHP Addon for the PRo Platform: PRO/NVX Current Version: 1.5 PHPLogCon (08/28/10) PHPlogcon is now called Log analyzer Based on 3.01 (3.0 beta) correct a bug on remote syslog syslogd will accept connection from other system add users log add frontview error log (choose web log format) Installation Notes: you need to install PHP addon first if not already done user is admin with your frontview password Screenshots: Old Versions: Removed Credits and Sources: Log analyzer web site add frontview error log (choose web log format)Cacti
CACTI Description: Cacti is a complete network graphing solution designed to harness the power of RRDTool's data storage and graphing functionality. Cacti provides a fast poller, advanced graph templating, multiple data acquisition methods, and user management features out of the box. All of this is wrapped in an intuitive, easy to use interface that makes sense for LAN-sized installations up to complex networks with hundreds of devices. Requirements: RAIDiator 4.2.1+ Platform: X86 Current Version: 1.9 Removed (07/24/10) Better check of php installation (should solve frontview crash in some rare case) Include all files for PHP support no more need to install PHP first it's a all in one Cacti can now be disabled UPS Monitoring (10/26/08) X86 fans and T° monitoring Cacti is now located in /c/webroot/cacti Readynas templates are in /c/webroot/cacti/Readynas Monitor and Discovery plugins are included (configure it to the the tab in settings/misc) NV+/duo/1100 fans and T° monitoring (10/26/08) Based on 0.8.7.e plugin support added Installation Notes: user is admin with password : admin after installing and first login you will see some error message to avoid it enable snmp in the cacti global configuration you must import xml files located in webroot/cacti share in Cacti UI :) Screenshots: Old Versions: Cacti Credits and Sources : Based on 0.8.7.b plugin support added cacti web siteAutomatic (curr: 0.6.2)
Automatic 0.6.2 Description: Automatic is an RSS downloader for Linux based systems, that grabs your favorite torrents based on filters you specify. It was designed to integrate with the popular BitTorrent client Transmission (http://transmissionbt.com). Any torrents grabbed by Automatic are directly added to Transmission, effectively making it an auto-downloader. Requirements: RAIDiator 4.2.9+ Platform: Intel Current Version: automatic_0.6.2-readypro-0.9.2.bin Details: This addon contains the automatic binary (located in /usr/local/bin) and a sample configuration file /etc/automatic.conf-sample. It doesn't provide a graphical or web based setup, you have to rename the supplied sample config and edit the file as needed Donations: If you like this addon, please donate.
