ReadyShare stopped working
1 TopicREADYSHARE options keeps giving blank pages, can't change add folders
READYSHARE options keeps giving blank pages, can't change add folders. I have the newest firmware version 1.0.2.32 on a Nighthawk(R) X4S R7800. Other people had similar the same problem in the past and the solution sugested was to format the HD with NTFS but my usb HD has been NTFS to begin with. The problem is inconsistent. Some times it gives me a blank/gray screen when I click Advanced Settings and sometimes it gives me the correct options. However, when I get the options if I click to make a new folder it gives me a small blank window and stalls. I've been at it for hours. Everything was working at first but then I deleted a folder and I was not able to use the feature again. 08/10/2017 ThanksSolved3.2KViews0likes4Comments
