Recover data from disks
1 TopicReadyNAS 102: how to recover data from RAID-1 disks?
How do I recover the data from the 2 RAID-1 disks that used to be a ReadyNAS 102 (FW 6.5.0)? I have SATA-to-USB cradle/cable and run a Windows 10 PC. Basically, after the upgrade to FW 6.5.0, the system became unstable: (1) it crashed every few hours; (2) rebooting would often hang with a blinking power button, and I couldn'tg reach my volume; (3) if it did boot all the way, and I could reach my volume, the power button would still keep blinking, and soon the volume would become unreachable. So I pulled the 2 disks out (configured as RAID-1 and tried re-installing the OS through the boot menu. Now, nothing works. When I re-insert the same two disks, RAIDar is able to detect the chassis, but shows no disks. AND the power button perpetually blinks. Thus, I've decided that I should give up trying to read the disks in the RN102 and just recover the data from the disks manually using my PC. At no point did I do a factory reset, so all the data should still be on my two disks. How do i recover the data from the 2 RAID-1 disks using my PC?Solved23KViews0likes25Comments
