Remove inactive volumes
2 TopicsX-Raid Verticle Expansion Incomplete
Hello, I have recently attempted a Verticle Expansion of our array from X-Raid (6) 12X3TB by replacing with 4X6TB drives. I replaced one drive at a time allowing amply time to resync, verifying online in the logs for each. On the 4th drive, upon completion, I had expected the volume to expand; however, the following resulted "Remove inactive volumes to use the disk" Several reboots later and firmware update i am not much farther ahead. Is this normal and what have others done in the community to deal with this? Firmware 6.9.3 Regards, DaveSolved2.5KViews0likes14CommentsRemove inactive volumes to use the disk. Disk #1,2,3,4.
Hi, I'm getting the error message Remove inactive volumes to use the disk. Disk #1,2,3,4. and am trying to understang what is going on, but I'm a bit lost with the logs. What do I do? By the way, I had the error putname+64 on the LCD display after a reboot, just before I got this scarry error message. Firmware 6.6.1 (where is the new one??? D: ) Kind regards, Charles p.s. logs sent (subject: Remove inactive volumes to use the disk. Disk #1,2,3,4 RN104)3.8KViews0likes5Comments
