Router Id Fail
1 TopicAC1750 - Genie Parental Control Fails Checking Firmware, OpenDDS working. Wifi Not, Cannot Disable
Hi, Scan topics and have not found solution. AC1750 and Genie Issue, Win10 Pro, Enabled Parental Controls, created OpenDNS and appears all appeared well execept WIFI devices not accessing internet. WIFI devices have connection reported by AC1750 console and Genie. Genie version is 2.4.54, AC1750 is V1.0.1.38_1.0.25 So Trying to reset, undo, DNS via AC1750 Web console. Won't allow modifications without disabling Parental Controls. VIA Genie, appears all menu selections working EXPECT depressing Parental Controls results in failed Checking Router Firwmare, check internet connection.... Thus cannot get past this to disable Parental Controls to reset dns settings to get back to orignal configureation before I let the "genie out of the bottle" Cannot change AC1750 DNS settings to undo OpenDNS settings. Don't want to reset AC1750 due to rules, vpn, vlan settings. So 0) Symantec Endpoint firewall disabled. 1) Ethernet Connections working fine with OpenDNS filtering. 2) Genie will not get past detecting router via Parantel Controls. 3) Wifi Not connecting to internet or to AC1750 web console. WiFi Adapter DNS = 208.67.222.222 , 208.67.220.220 4) Web connection to AC1750 shows all PC and Wireless connections active 5) Netgear Genie Shows Network Connections, Wifi connections, router firmware vesion. 6) Genie > Router Settings > returns V1.0.1.36 as expected. Ideas?2.2KViews0likes3Comments
