SRX503 multi WAN UP
1 TopicSRX5308 multi wan connexion UP
I have an SRX5308 with two WANs (a 100Mb WAN1 fuse and an adsl 5Mb WAN2 backup) I need both links to be up all the time (as in load balancing mode) because there are open ports on the Two links, but I want the majority of com lan to wan go through fiber (WAN1)? How can I do ? if i config load balancing, link's are UP but sometime internet trafic goes thru ADSL (WWAN2) if i config rollover ADSL (wan2) is DOWN Thank'sSolved7.2KViews0likes9Comments
