SSLVPN tunnel
1 TopicIPSec VPN tunnel between SRX5308 and a FVS336Gv3 suddenly changes to a SSLVPN tunnel
I had an IPSec VPN tunnel between a SRX5308 router and a FVS318G router had to change the FVS318G router went to a FVS336Gv3 router. Set up the IPSec VPN tunnel on the 336Gv3 router and all was fine for a couple of days, I then realized the IPSec tunnel was not working I investigated and found that a SSL VPN tunnel had replaced the IPSec one. I did not set this tunnel up the client address range begining and ending are no where near the client address ranges we actually use. Also there is no info in the DNS Suffix or the primary or secondary DNS servers. 1.) Can anyone please tell me what happened? 2.) As well as how do I fix this or turn off the SSLVPN tunnel and re-establish the IPSec tunnel 3.) Or is the SSL tunnel better than the IPSec tunnel? Thank you in advance for any assistance on this problem.Solved4.1KViews0likes6Comments
