Security
301 TopicsNetgear C7000v2 USB Not showing NAS (Network Attached Storage)
I have a c7000v2 Netgear router/modem. I am trying to install a NAS to the USB port located at the top of the router. I have a 64 Gig Flash drive plugged in. When I log into the router, the Genie software runs. At the home tab the USB Icon in the middle of the second row shows a green READY notation. When I click on the USB icon/button it takes me to a second screen showing USB Storage (Basic Settings). Basic radio button is pushed. Network/Device name is listed as \\readyshare. Available Network Folders has NO DEVICE LISTED. Buttons EDIT and Safely Remove USB Device are AVAILABLE. (When no Flash drive in USB Port these buttons are not available.) Under the Advanced Tab/Advanced Setup/USB Settings I have Enable any USB Device connected to the USB port YES. When I click on Approved Devices I see my USB Drive name listed under Available Devices Device Name Is Generic USB Storage and space is 60 gig. I selected it with the radio button and added it to the Approved Devices List. The Allow Only Approved Devices check box IS NOT CHECKED. These Setting have been saved. After all of this and pressing Refresh a couple of times after a few minutes, the Basic Settings still DOES NOT LIST MY DEVICE. I cannot find this device on my network although with windows I can see \\readyshare available under NETWORKS. However clicking on it shows nothing and I cannot copy anything to it. The Flash drive is formatted NTFS and there are a couple of folders created at the root level. Any help getting my flash drive to show up in the USB Basic settings I feel would correct the problem but I cannot figure out what else to do. Any help would be GREATLY APPREIATED. REGARDS and THANKS FOR READING and RESPONDING.1.3KViews0likes2CommentsSecurity Concerns. C7000v2
Hi All, the past 8 months i have been monitoring something strange on my network. As a tech illiterate, it has been an evolution in trying to understand what is happening. Hopefully there is either some answers or reassurance out there. -NightHawk C7000v2 Combo -Firmware is V1.03.08 -ISP is Xfinity Cable Question: -On my admin page, i have DLNA turned off, confirmed many times, on the nighthawk app there is no DLNA server present. On the below Fing network tool screen shot below you will see it is present. it always is, except for about 1-2 hours after i factory reset the Gateway. then it returns. how do i remove completely and why would it not show on the App interface? -On the screen shot there are 6 active devices on that network, two are accounted for as my iphones, the others including the DLNA server 10 (11,30(not pictured)) should not be on this Channel. In an attempt to be more secure, I have restricted "new 2.4" to only my two phones, there is nothing I have ever typed that password into other than those 2 phones. All other devices in my house, both family and friends use the 2.4/5 guest network channels and those are the only SSIDs broadcast. there should be no trace of New 2.4 to anyone but me. I am wondering how other devices show up on this channel. Please note all info is based on this third-party app i am using. It has been pretty accurate in the past for devices coming and going on my guest network. -Check out the screen shot where it shows my gateway, which is absolutely a NetGear nighthawk. the gateway says c7000v2, but adjacent to it, it says Motorola surfboard sbg6580. I found screen shots of the same app, from last fall, the same place it says Netgear CSIS 3.0 Cable Modem Router. I cannot reconcile that in 6 months' time, the same app has confused the hardware. this has led me to concerns for what is triggering the error in labeling. -Lastly, what has caused me to come looking for more information, the aforementioned segmented networks, consists of a 2.4 and 5Ghz Channel, for the last 3 weeks, although i can access and log on the 5ghz channel, there is never any actual connection available. I can join, password connects, but my phone defaults to carrier service and the WiFi dashboard on my iPhone says "no internet connections" this is all day everyday. I have reset the device multiple times in those 3 weeks and changed the password. nothing has fixed it or changed it, it still shows as i can connect, but no Wifi data. Any insight to any of the above would be greatly appreciated. thank you all for your time!3.6KViews0likes10Commentssync time synchoniztaion failure, streaming buffering
I started having issues with select streaming services buffering about a month ago. I installed cm1000v2 modem with eero mesh system and the problem sill persists. The log shows sync time synchonization failure errors. I don't know anything about networks and errors. Called Netgear router help line and was told I need to activate security on the modem which is only free for the first week and then I have to pay $149 a year?? So I don't think I should have to pay for my router to work, and honestly since this started before this router was installed I have no confidence that paying will fix the problem. Can anyone help me understand if this is a Netgear issue or an ISP issue? Or another issue? I am nearing my wits end with my streaming not working! I have 500 Mbps speed, have unplugged and replugged, uninstalled and reinstalled, changed my whole Internet system, called Hulu support, emailed peacock support, nobody will tell me how to fix. No uncorrectable codewords in log, argh!Solved17KViews0likes12CommentsNighthawk CAX30 required login for internet
I have a brand new CAX30, and when I hooked it up and got it activated by my ISP, I was unable to access the internet without logging in. This is after I put in the pass for the wifi connection. When I bring up a browser, it tells me I need to log in (like connecting to some of the department store guest wifi's), but doesn't give any user/pass or button to click OK. How can I turn that off? Thanks, Jchopp1.3KViews0likes4CommentsCAX80 Disconnecting me from Call of Duty MW2 servers
Hi everyone, Currently have a CAX80 and I am unable to play MW2 Online before it disconnects me for server issues. It's not Activisions servers nor is it my PC as it works with my old router/modem. I even tried portforwarding and switching to a static IP(which caused my wifi to go down.) Don't know what to do or try at this time. Can anyone help with this?592Views0likes1CommentI accidentally myself by blocking new users in access control
Help, bought a brand new NETGEAR modem router AC1200. Had a hard time installing it but after I installed it, I went to access control and block any users who try to access. However I accidentally blocked me too. Now I can’t access without seeing a black screen with two red line, one on top and bottom. How do I start this router from scratch again and resetting it a couple times didn’t help? How do I get it working again?857Views0likes1CommentNO RANGING RESPONSE, DoS attack, C7000v2 on spectrum
Ok so I have few problems. 1. I keep getting this message from my event logs. | No Ranging Response received - T3 time-out;CM- MAC=94:a6:7e:20:14:14;CMTS-MAC=00:17:10:88:25:62;CM-QOS=1.0;CM-VER=3.0; SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:20:14:14;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;| Over and over I have rebooted several times, and have factory reset several times same thing. 2. I’ve been getting this message from my regular logs. | [DoS attack: TCP- or UDP-based Port Scan] from 209.18.47.62, port 53 And LAN access from remote] from 193.163.125.192:41455 to 192.168.0.12:3479 LAN access from remote] from 167.94.138.103:62577 to 192.168.0.12:1723 |883Views0likes1Commentc6900 wifi router
After factory resetting my router I was finally taken to the page to set it up. I logged into the netgear geni via the browser it took me to without incident. However it allowed me to access 3 different areas then suddenly it started saying cannot access due to insecure security settings with a Mozzila logo. I decided to try using microsoft edge but it did the same thing. So hey thanks to everyone for helping me log into it unfortunately I must report it was to no avail. Any suggestions on what to do now? Oh and the desktop geni app doesn't work with my router. Thanks in advance Also now I can't even reach the login page http://www.routerlogin.com/genie_index.htm again, it goes back to netgear.com absolutely unacceptable- NETGEAR do BETTER!!693Views0likes1Comment
