Status=-28
1 TopicRN2120 iSCSI Create LUN failed
Dear All, Max LUN size available is 9.81TB When I create this, nothing happens. When I create a 5TB LUN, it creates it perfectly fine. If I attempt to expand this LUN to 9.81TB, it gives me an error: ### Folder operation failed. ### 21003020028 ### Modifying LUN properties has failed ### Code: 21003020028 I checked the Log files and I have one entry (when the initial 9.81TB was created) which says: ### Create LUN failed (status=256) When I attempted to expand it (after creating the 5TB one to 9.81TB) ### Modify LUN failed (status=-28) I've tried to expand the LUN incrementally, and I can get a single LUN to 8191GB (1GB short of 8TB) The rest of the space I have to create another LUN. I'm unable to create a single LUN. I've tried doing this on Firmware 6.5.0 and downgraded to 6.4.2 aswell to try it, still no luck. Any idea on how I can create a single LUN at 9.81TB in size? If not, why is there a limit? Kind Regards...Solved4KViews0likes3Comments
