TX & RX
11 TopicsTransceivers compatibility with the M4250-10G2F-PoE+
Hello, I have a Netgear M4250-10G2F-PoE+, i'am trying to etablish a fiber optic link with a D-Link DGS-1520-28XMP. I had tried two pairs of SFP+ which are compabile with D-Link but each time the fiber optic link isn't etablished. When i look on the logs on the Netgear, it detects the transceivers put in the port 12 but i don't understand the errror message : <189>Jun 24 14:22:18 192.168.1.235-1 TRAPMGR[boxs_Req]: traputil.c(885) 400 %% NOTE Temperature state change alarm: Unit Number: 1 Current: Normal, Previous: None <188>Jun 24 14:22:18 192.168.1.235-1 NIM[nim_t]: nim_events.c(1702) 399 %% WARN Set Autoneg capabilities 0x0 for 0/12 returned error 0x1 due to capability changes <189>Jun 24 14:22:18 192.168.1.235-1 TRAPMGR[trapTask]: traputil.c(841) 398 %% NOTE SFP+ inserted in 0/12 What means the errors returned error 0x1 due to capability changes ? Which brands of transceivers can-i use to make a working SFP+ optic connexion ? Thanks by advance15Views0likes1CommentSDVoE system advice - routing without PC
Hello, is it possible to do something like on picture shown bellow with SDVoE system? Whatever you put into Input X, must be routed to all output Xs If you plug 2 or more cables to input X, switch must be able to handle this somehow and not cause any errors - ideally it should route the latter connected cable Switch with at least 12 SFP ports Should work without PC, PC only for configuring the switch The idea is: we have 1 big monitor (Output 1) connected over SDVoE Tx/Rx to a PC (Input 1). In the same room we also have a lamp camera and HDMI patches for laptops (Inputs 2). All this will be also connected over SDVoE Tx/Rx to 2x display and 4K capture card. So what I want to do in short is to split the ports into 2 or more groups of "Inputs" and "Outputs" where input would be routed to all outputs in that group. Thank you!282Views0likes4CommentsConfigure NDI profile using IP space/DHCP from Circuit router/Switch
Hi, I have a master network router/switch connected to the circuits providing DHCP. It feeds the M4250 through Port 26 In Default profile all connected devices get a DHCP IP address from that master router. I want to create a NDI profile VLAN for ports 1-10 that will also get IP addresses from the master router. When i did this i had to Switching-->VLAN-->VLAN Trunking Configuration--> change ports 1-10 to Switch port Mode: Trunk and Access VLAN ID: (10 - NDI VLAN Number) to get it to work. But that looked to disable the NDI configured profile. Lost color code and # of assigned ports What would the right configuration for this preserving the NDI VLAN? **ALL Devices in the workflow are controlled via web admin. Thank you!558Views0likes0CommentsWhich profile for qlab
Hi I am trying to set up qlab to run through a separate vlan. It is currently set on a data profile but the issue I have is I think some settings are not correct as the qlab profile also has a midi time code on it due to the amount of sacn and artnet I’m using I kept it on a separate network vlan. Which profile would be the best one to use for qlab to talk between 2 machines and also have a time code unit sitting on it566Views0likes0CommentsSFP+ not getting link on M4250
Hello! I'm trying to connect two M4250 switches via SFP+ using two AXM761 multi mode fiber modules. The modules are correctly shown in the Port Transceiver page of the switch and marked as supported, but when I connect the cable I cannot establish a link between the two ports. Link status remains down as if the cable is disconnected. Already tried another cable and also other transceivers (same model). Am I missing any configuration steps? Thanks for your help!1.8KViews0likes1Commentonboarded M4250 has no configured profiles
I am using Engage Controller to manage seven M4250 switches. Six of the switches appear to have onboarded properly, but the seventh does not show the configured profiles on its Configure page. How can I get that switch to show the configured profiles? M4250-26G4F-PoE+ (GSM4230P) #EngageSolved5.8KViews0likes3CommentsBuilding LAN to AV LAN communication
Trying to get communication between iPad (Crestron xPanel) on client LAN and Control Processor on AV LAN. I was thinking a port forward setup would work but I don't see that in the UI at all. Wondering if it is called something different, not available or if there is another way to accomplish what I am trying to do. Simplified diagram attached.2.3KViews0likes2Comments[NDI] Multicast UDP Packet Loss with Multiple Streams on Windows PC
The following is a version of an email I sent to Netgear's ProAV Team already. Already had a good conversaion with NeilS and Netgear is going to look to do some internal testing. Note that I don't think these issues are necessarily a Netgear issue, but we're all just trying to understand what might be going on. Tl;Dr: A Windows 10 PC is dropping frames while receiving 4x full bandwidth NDI sources in multicast UDP mode on it's gigabit NIC. Ethernet bandwidth doesn't exceed 550Mbps and PC resources are not maxed out. Switching source devices to unicast TCP solves the problem and bandwidth doesn't change. Why? I'm an AV integrator and I have a site where we deployed a system with some NDI (full bandwidth) cameras, encoders, and decoders using a M4200 (edge switch for cameras, providing PoE) and a M4300 (connected to M4200 by 10Gig copper). I know the M4200 isn't "certified" for NDI, but it met the requirements for the application and I didn't see anything wrong with chosing it. It's quiet, has PoE+, low port count, and 10Gig uplink. I liked the NBASE-T for future too. Out of the gate, I configured everything for multicast because it's more bandwidth efficient. The M4200 and M4300 multicast settings are all fine and that part of the system is operating normally. The switches are all configured according to the NewTek NDI deployment guide, with flow control enabled, jumbo frames and QoS disabled, etc. LaurentMa had previously reviewed the configuration. They have a computer (Core i7-9700, 16GB RAM, GTX 1650, NVMe SSD) running BirdDog Multiview program to display 4x NDI sources in a 2x2 grid. So, this PC is configured to receive 4x full bandwidth (not proxy) NDI streams. All streams are 1080p30 but we've tried 1080p60. I've been troubleshooting freezing video, lost frames, etc for quite some time. The PC is not maxed out on resources. CPU sits at around 60% and GPU maybe 25%. Ethernet bandwidth is generally around 550 Mbps or less. I've also tried to use 4x instances of NewTek NDI Studio Monitor instead of the BirdDog program and performance is slightly better. However, the BirdDog program outputs NDI of the multiview which is used on other destinations on campus. I finally had a revelation about using multicast the other day -- the packets are all UDP with multicast, and so there's no acknowledgement of packets and I believe I'm just losing frames as a result. I suppose the frames I do get may be more timely? To my surprise, I switched the cameras and encoders all back to unicast TCP instead of multicast and performance was immediately flawless. Ethernet bandwidth on the PC didn't change. The frame loss was never visible on a Panasonic AV-HLC100 switcher (which is basically a NewTek TriCaster product). However, I think that the unit only receives 1-2 full bandwidth NDI streams (preview and program bus sources maybe?) and the thumbnail previews are all proxy. For this installation, no NDI source is routed to more than 2x or 3x destinations, so I think I'm OK using unicast for now. I am more familiar with other AVoIP solutions such as AMX SVSI, Crestron NVX, Wyrestorm, etc... and all of those use multicast for video as far as I know. One difference though, is a single decoder only receives one stream. It seems to me the problem lies with one of these things: Is there something about a single computer receiving multiple streams that is causing problems? Does the Ethernet stack or NIC have a UDP buffer that is likely getting full? Or is the NDI library not processing the buffer fast enough to keep up? Or does Windows or the NIC prioritize TCP traffic over UDP? I realize in general that UDP is unreliable but no one ever mentions this in regards to multicast NDI. In fact, it's been recommended to me to deploy NDI in multicast since I have switches that support it, I know how it works and how to deploy it, and I am sending sources to 2 or more destinations... so it made sense to do multicast. If you're unfamiliar with NDI, it is NOT multicast video by default. In fact, all of the "plug and play" bit about NDI is more related to doing a low number of sources or destinations and just running it as it ships. You have to manually switch sources to multicast. If you have managed switches, multicast config probably does help for the mDNS traffic. I know NDI has the ability to "load balance" across multiple NICs without the use of link aggregation. Would that help this problem? How does this actually work since we don't specifically bond an NDI stream to a particular NIC? I am so not sure how this would work in multicast unless both NICs join the same multicast groups and it figures out which packets are missing to stitch the streams back together. I can try to run a iperf3 test at some point, but given that the UDP streams are flawless on other devices on the same switch, and the streams are flawless when viewing 1 or 2 at a time on this PC, it doesn't appear to be a network issue. Open to any ideas or experiences with similar setups. Thanks!4.1KViews0likes0CommentsNETGEAR - Accelerating AV over IP Adoption #Webinar
The Pro AV market has been slow to fully adopt AV-over-IP technologies. In his webinar we investigated why this is the case and examined what NETGEAR is doing to help accelerate the adoption rate. This presentation is a must-see for all sales or marketing professionals who are new to AV over IP technologies in the Pro AV segment! A replay of the webinar is posted below, or view our AV over IP webinar on Youtube.
7KViews0likes0Comments
