Tech Support mode
1 TopicRN104 Stuck In Boot Menu Mode/Normal after firmware upgrade 6.6.1
Last time I logged into my RN104, it offered me a FW upgrade to 6.8.0. I accepted. Something went horribly wrong and my NAS became unusable - completely. My data's fine due to having off-site backups. But, the RN104 is toasted - sort of. When powered on, it wants to (only) boot USB. So I prepared a USB recovery flash drive. It went through the process and powered off the NAS. I powered back on and nothing. It wants to only boot USB. Trying multiple flash drives didn't help. But, in one of those attempts, I neglected to copy the <firmware>.img file to the USB drive and the unit dropped into tech support mode (LCD says "DEBUG $PORT $IP Recovery"). I can use RAIDar to find the unit. It says: Model: None Name: readynasos Serial: NONE000200000 Status: Tech Support Mode Firmware: 6.2.4 IP Address: 198.162.29.190 (28:C6:8E:35:20:6A) Debug code: TELNET Mode I can login via telnet as root, with pw infr8ntdebug. From that point, is it possible for me to reset this whole thing to Factory Defaults or do an OS Reinstall? I have a disk drive I can use in it for this exercise (I'll upgrade to larger, real drives if it works). How would I go about that? Thanks!6KViews1like33Comments
