Usb drive disconnecting
1 TopicUSB drives are loosing configuration after reboot
Hello all, I have two USB drives connected. Once I do configuration of ReadyShare folder path for both of them everything works just fine. But when router reboot or power cycle,then directory path configuration for each USB port mix up and finally are not working. To get it work I need to map them again in web UI. Is there any way how to avoid loosing configuration of usb paths when reboot or power cycle? I use latest stock firmware. Thank you in advance for any advice. Kind regards MiraSolved6KViews0likes11Comments
