VPN disconnected
2 TopicsReadyCloud VPN Disconnected - Apple desktop app
Hi all, Problem: Readycloud VPN Disconnected OS: Apple 10.13.3 MBair and MBpro Readycloud Desktop version: 1.6V I think this has been raised before but Im having it happen across most of my macs again. We can connect with readycloud app while we are on the same network but as soon as we go outside the network and try to connect we get this error as above. I have disabled the IPv6 on the Netgear server but this has not helped. The Strange thing is my MB Pro at home connects to the server useing Readycloud version 1.5v. So I tried replacing the contents of the Readycloud version 1.6v. app with my 1.5v but it didnt work. does anyone have any ideas. Also does anyone know how to use ReadyCloud Network, Manually set proxy server settings? and would this fix my problem? Thanks All Regards Ben3.9KViews0likes6CommentsReadyCloud "VPN Disconnected" Still a Problem Logging In
For months now I would get the occassional "VPN disconnected" notice - like many others have experienced - when I tried to login to remotely access my files from a laptop, using the ReadyCloud desktop app. Back then, I could at least log out and back in or restart the app and it would start working again after one attempt. However, this is no longer the case. Ever since the ReadyCloud outage that lasted hours around a week ago, I now go some 10-20 attempts at this before it finally lets me in. It takes about 30-45 minutes of retries. Any ideas to fix this? I'm running v1.15 on Windows 10 Home edition.
