WAC730
3 TopicsWAC730 Captive Portal - Facebook - Issues
WAC730, standalone, v3.8.3.0, two SSID in service, FB Login proof of concept for customer demonstration Created a new SSID, assigned the second captive portal NETGEAR-1 Configured the second captive portal NETGEAR-1 (why ever this profile name can't be renamed - Netgear does still not understand [my!] profile design concept you have stolen from another vendor), Captive Portal Mode (x) Enabled, Register with Facebook WiFi (x) Yes, Profile Name NETGEAR-1 [x] Admin enabled, Authentication mode: Facebook Wi-Fi, Facebook page: [set]. When accessing the SSID, the captive portal page does show up very unreliable - all current Windows 10/Android/iOS/macOS. When it does show up, we can check in to the Facebook site. And the access works kind of as expected. IF you have ever the chance to check-in on the FB site. [ISSUE!] When now attempting to manage the WAC730 over the LAN, the Captive Portal does jump in - why ever, always. Regardless if calling https://wac730-1.[whatever.dom.ain]/ or https://[WAC730-LAN-ADMIN-IP]/ (same with http), the FB WiFi Captiv Portal does jump in: ...now we're nice, and [Check in] at the site... ...we can click on [Continue browsing] as many times as we want, the browser does call the LAN IP (as originally requested), and the [Continue Browsing] page does come up again. The WAC730 Web UI is not accessible over the LAN at this state. Even if trying a new session, a different browser - we're really captured. But not by accessing the SSID ... by attempting to manage the WAC730 over the LAN! Obvious [BUG]. Firmware is current as of Support / WAC730- ProSAFE Business 3 x 3 Dual Band Wireless-AC Access Point v3.8.3.0. Proof of concept failed, looks like we won't get an order Netgear WLAN equipment for this customer RaghuHR. Bugware. Untested. Back to the skunkworks. Now I don't wonder why the Nighthawk router model(s) supporting FB WiFi are suffering from basic functionality issues as well.Solved5.4KViews0likes6CommentsCannot connect to WAC730 after factory reset
Please help. I am unable to access the AP after a factory reset. All the lights are coming on as normal. The router sees it and assigns it an IP. However, when I try to access the management page on that IP I get no response. I tried on 2 different routers. I know the reset occurred because the broadcast SSID reverted to the default. When I try to connect to the default SSID i dont even get an IP address assigned. The reason I had to factory reset is I incorrectly setup a vlan and the AP got isolated from the network and became inaccessible.Solved11KViews0likes12Comments
