WN3000RP-100PAS
1 TopicConnecting my WN3000RP-100PAS to my Router via PowerLine
I recently purchased a WN3000RP-100PAS and I would like to use it as an Access Point and connect it to my WiFi internet Router through the my power line. I have an older NETGEAR PowerLine (I believe it is the Powerline AV200 Adapter XAV201) that my router has an Ethernet connect to. I am using several older NETGEAR Powerline's in my house - all working fine. Is it possible to configure the WM3000RP to access my router through the Powerline? I was told 'yes' before I bought it, but I cannot figure-out how to make the WM3000RP connect to my router thought the Powerline. I did plug it in to an outlet near my router and connected it directly with an Ethernet cable and this worked.Solved4.8KViews0likes6Comments
