Wi-FI
2 TopicsR9000 - Can't turn off WiFi using hardware on/off button
I have a Netgear Night Hawk X10 R9000 I purchased a couple of months ago, and I’m having some issues with the Wi-Fi button on the front......the 2nd button from the right, next to the WPS button. When I press and hold down the button for two seconds, the button lights up along with the 2.4GHz, 5GHz, and the four antennas......but here’s where it gets interesting. When I again press and hold down the WiFi button (2nd from the right), the button light goes out, the 2.4GHz, 5GHz, and the antenna lights go out, BUT.....the WiFi is still active on both the 2.4 and 5GHz bands (I still have WiFi Internet!!). Consequently, how could I still have WiFi Internet if the lights on the antennas are off, and the 2.4 and 5GHz lights are off also? The only way I’ve found to turn off the WiFi is to turn off the SSID broadcast for both the 2.4 and 5GHz bands in the router setup, but this is a real pain. I’ve updated to the latest firmware, but still no fix. NOTE: I’m NOT using the WPS feature / button; whereas, I’ve never got it to sync to any of my WiFi devices. Any suggestions or fixes?Solved4.2KViews0likes4CommentsR7000 Wi-Fi speed dropped off 300%
I have the luxury of a fiber optic connection which gives me almost 1000 Mbps up and down hard-wired and which WAS giving me around 400 Mbps up/down wireless as well, but now it's down to around 100Mbps up/down wireless - but hardwired still at original high rate. My service is Giggle Fiber in Monrovia, CA, and they say it's a router issue because hardwire speed proves their end is OK. Accessing wireless with Mac Air, iPhone, PC. Wired with PC and iMac.Solved4.4KViews0likes4Comments
