Wired Access Point
1 TopicOrbi as a Wired Access Point
OK i've read the options but it is not clear if Orbi can be installed as a Wired Access Point. In other words, in an existing network, off another router. Not looking for the router funtionality, since I already have a great router, but as an WiFi expansion by being plugged into the wired LAN port on the network. Reason for the need it is because of the distance of the current house. Also will it work along side the current Wifi?Solved
