Wired repeater setup
1 TopicWNR2200 Possibities: Extend network seamlessly?
Hello, I'm trying to extend my WiFi range by setting up a second Acces Point further down the house. This second AP is the WNR2200 (FW V1.0.1.96) and is connected to AP1 (from provider) through powerlines. I have managed to set it up as a second network, but this of course requires manual change on mobile device as long as AP1 is within range. I want to avoid this and make the network seamless. I think I know what to do, but it won't work so far. - So I have AP1: 192.168.0.1 and AP2: 192.168.0.80 - Both on WPA2 and same password - DHCP disabled on AP2 - Different wifi channels (Was looking ages for the WDS function, which is mentioned in the manual, but then found out is has been removed since newer firmware versions...). Now my questions are: 1) Is it possible to do this with the WNR2200 connected to an AP of different brand? (Because nothing of repeating is mentioned in the manual, except for the obsolete WDS.) 2) If yes, is there a setting I have missed? 3) !!! What is the difference between the IP set at "BASIC -> Internet -> Fixed IP" (with me at .0.80) and "Advanced -> Installations -> LAN settings" (with me at .1.1)? 4) WDS is only for wireless extention right? Not when AP1 and 2 are connected via cable or powerline? And just out of interest: Why has WDS become obsolete? Any input would be appreciated, Thank you, JonSolved6.9KViews0likes5Comments
