add-ons
2 TopicsSickrage not working after re-install ReadyNAS 102
Hi guys, I've had the Sickrage app installed from WhoCares_ but I was having trouble updating it to the latest git. So I decided to remove it and install the version from Mhynlo After installation, the app seems to be installed correctly; the status is ON in Frontview, however the app doesn't work. When I launch it, the page http://192.168.1.13:8081 opens, but the Sickrage page is not working. I've tried removing the app with SSH: I logged in as root and ran apt-get purge sickrage Then: cd apps rm sickrage -r The latter command returned 'no such directory.' I reinstalled the app again, but it still doesn't work... :( Any ideas?Solved4.6KViews0likes10CommentsLogitech Media Server: App "off", still running
After upgrading to 6.4.0, Logitech Media Server got slightly borked. The app icon is no longer displaying, the app is permanently listed as "off" (see the screenshot), and yet—thankfully—it's still running. Is there an update to the app that works more reliably with the current OS6? (It was developed by s-p, if I have his new username right.)4.9KViews0likes6Comments
