airport express
1 Topicairport express connection with orbi
Setup orbi network twice. From factory reset. Airplay will join the network using airport utility software. when I try to airplay sound from any device on the network it will not connect. I have moved my satellite. For some reason, the airports are connecting to the satellite on 5ghz network. I have MU-MIMO off right now. To test it again and have a support ticket open. I also picked up a eero and airports and airplay work fine. Also, works fine with airport extreme.
