ax12
28 TopicsMS80 Satellite cannot connect to router
Hi I have three MS80 mesh satellites and a MR80 Router. They were all working after initial install about a year or so ago. One of the MS80s will not connect to MR80 Router. I tried reboot, reset no avail. When I plug in the MS80 the light flashes white then goes amber. I hit the sync button it starts white and then goes amber again. I don't know what it wrong and any help would be appreciated. Thanks2.1KViews0likes3CommentsRAX500 2.4 not allowing devices back on once disconnected.
I have a RAX500 Router, Firmware up-to-date and have had if for about 8 months. I have about 85 device connected/ Hardwired and 5G /2g connected. Over the last couple months I have had many issues with when a device goes offline it doesn't reconnect to the 2.4 until I change channel in the settings. Example my Alexa stops working unplug it still not connecting. Go to the app and try to configure it back to my 2.4 network and can't connect. I go into my router settings and change channel and it will reconnect. I also noticed that once device drops and doesn't connect any new device will not connect to the 2.4. Meaning I try to switch my phone / tablet from the 5G to 2.4G and doesn't connect. It only works when I change the channel. Also I have 2 Netgear wifi extenders their 2.4 G will allow me to connect devices when the main 2.4 doesn't.Replacing BT Home Hub 6 with DrayTek Vigor 130, then connecting to my Nighthawk RAX200, step by step
Replacing my BT Home Hub 6 with DrayTek Vigor 130, then connecting to my Nighthawk RAX200, step by step guide if possible. Hi. Looking for some not-too-techie guidance and help, if possible. My plan is: - I replace my existing BT Home Hub 6, with a DrayTek Vigor 130 modem - then, attaching my Netgear Nighthawk RAX200 to my new DrayTek Vigor 130 modem. - Can anyone give me 'an idiots guide' for how to configure my RAX200 for perfect harmony, between the Vigor130 and the RAX200 units. - do I perform a factory reset of the RAX200, so automatic configuration can sense the v130 modem and pick up up those settings - do I perform a factory reset of the RAX200, and manually set-up each section? If so, how... what should the settings be...? Any guidance, would be gratefully received. I want to slowly get the units into place, knowing I have reduced the option of failure, as much as possible. I have been advised I need to consider PPPoE, and DHCP. I also understand the Vigor will be in Bridge mode, which then leaves the RAX200 to manage the DHCP, and I have obtained then PPPoE information for my BT Broadband provision. You now know, all I know... but how do this... where to start, and each step until completion.. Many thanks, Martin (London)SolvedDDOS Advice
For the past 2 months or so, I've been experiencing major connection consistency issues such as fluctuating ping, reduced internet speeds, and even disconnections with my RAX75. I contacted the customer support from my ISP to see if there was any problems on their end, only for them to tell me it was a local issue. On Sunday, I decided to replace the router with the RAX120 and everything was running buttery smooth up until a couple of hours ago when I reconnected my Nighthawk EAX80 extender. NETGEAR armor sent me 5 threat reports of DDOS attacks blocked from the EAX80 and my Internet speeds were almost simulataneously destroyed. Every time I attempt to read the details of the threat reports the, app crashes. What are my options here?1.8KViews0likes2CommentsRax200 gaming help
So I recently bought a rax200 to hook up four gaming consoles. I have fiber to the house from my isp. I have also gotten a static ip which got rid of double nat type. Consoles lan in. And have reserved address. I have my nat type set to open and upnp enabled. It does grab work as I see it grabbing ports however the ports needed by both systems seems to be 3074 which for some reason only goes to one system. No matter what I have tried I keep getting moderate to strict on a few of them. If I port fwd or dmz that consoles in fine. I’m confused on how to proceed every YouTube video none seem to explain multiple console hook ups. Can have all four running and someone gonna get kicked eventually.RAXE500 email router logs daily/hourly not working
My email in advanced - security - email is configured properly with "daily" and "12:00 pm" set In administration - logs, I can send logs through email by clicking the "send logs" button. (a log entry is created) The issue is that I never see the logs sent at the scheduled specified time (or any time) It only works manually on demand What is needed to activate scheduling to have logs sent automatically? Firmware Version V1.0.1.52_2.0.34Mesh Network with VHT160/80 Support, Tri Band
Hello, I would love to have a mesh wifi 6 setup with 3 tri band client connections and using a cat6 dedicated network cable for router and nodes as my backhaul. With having the hardwire in all the nodes this should free up the third band for client use I would think or at least would be nice! Is there anything out like that or coming soon that you are aware of? I currently use a R9000 router with VHT160 (80+80MHz) channel width on 5GHz band. This router is running DDWRT since those are not standard factory settings... dont get me started on why! It works amazing with newer hardware like my Note 20 Ultra and other newer devices, except not the PS5. I read somewhere it supports up to 80MHz not 160. It can see the 5GHz network and it tries to connect but won't. I would like to have a VHT160 and a VHT80 on two 5GHz bands that way I can connect all my devices to 5GHz 80 or 160. I don't need a 2.4GHz band if I could get away with two 5GHz bands. But that isn't an option normally. Any suggestions on current mesh systems that would fit my request? Also if it matters or others care who read my post and have similar question, I currently use Google Fiber as my ISP and have a 1GB up/down speed so achieving super high wireless speeds is a must, also I have a large house so was at least looking at a 1 router with 2 node setup. Thank you for your help, CodyAX12 Nighthawk RAX120 DHCP and reserve issues
Hi, I've got several network devices. Both Wired and Wireless. I decided for security reasons to enable Access Control. I took a whole night adding each of my static and dhcp items to it's allow list. I also tried to reserve many of them so they would stop changing. I've never seen a Router that has so many inconsistancies with DHCP. Sure I have a lot of devices, but within surely within the limits. after all that time I found the next morning my cellhpone would not connect. It seems that DHCP eventually acts like it's released and renewed so much that my cellphone no longer can get an IP. Yet there are plenty non-reserved left. DHCP look screwed up in the logs, only showing 6, 2 byte values of the celphones MAC. Same goes with anything else that trys to connect. I have to reset the AX120, power cycle, 1 time even had to start over. But I have now given up and removed using Access Control. I have the latest FW loaded, but I have read oterh threads that suggest Newgear is aware of this and has been. I really ahte to have to set many of my devices to static. Anyone else know of this issue with DHCP. Thx, Nuke
