boot problem
2 TopicsRND-4000-200EUS - almost Almost working
Hi there, just picked up 2 of these with a fault (I think). When you plug the power lead in (with no drives present), the unit lights the power button, and starts going through a block progress bar, but stops at 2 blocks and appears to shut down. Is this normal, or is it something else, like the power supply? Any ideas?Solved3.6KViews0likes7CommentsReadynas 4200 doesn't load OS
After loading the latest Radiator version 6.4.1, our RM 4200 unit won't boot anymore. On the console during boot, the last two messages are: Loading initrd.gz Ready Cannot find the unit on the network with RAIDar. Cannot perform OSresinstall or FactoryDefault from the boot menu. Result is always the same. Please advise how to restore the original OS version and how get the unit back online. Thx, Itops_jasper3.8KViews0likes8Comments
