connection drop
1 TopicFSV318N connection drop and kernel emergencies and errors in log
Here are some of the messages that appear on my syslog server: [Kernel] Should overwrite TID here for NULL data [Kernel] xt_TCPMSS: bad length (589 bytes) [Kernel] <sppe_cmd_arp> Fail to delete IPv4 ARP entry according to my isp, the line is stable. according to my previous isp (yes I have changed isp's to check if it was their fault) it was ARP table related. The connection gets back online in about a minute or so. I have the latest firmware : Firmware Version: 4.3.5-3 These connection drops make me trust netgears stability less every day. We have a win2012r2 webserver behind it (opening port 80 and the port for ssl and ftp) which should be up and running 24/75.1KViews0likes10Comments
