cross-compile
1 TopicTrying to get SDK complete: apt-get update fails with 403 forbidden
When trying to install the readynas SDK into a chroot environment on Ubuntu 15.04, as described in http://apps.readynas.com/pages/?page_id=90 (with version for packages set to 6.2.3), the following errors show up when installing build-essential (see below). It looks like the package administration (or permission for the folders holding them) are incorrect. Who can fix this?? Kind regards Ger Kersten Err http://apt.readynas.com/packages/readynasos/ 6.2.3/main libstdc++6 amd64 4.9.0-7 403 Forbidden [IP: 54.230.53.71 80] Err http://apt.readynas.com/packages/readynasos/ 6.2.3/main libstdc++-4.9-dev amd64 4.9.0-7 403 Forbidden [IP: 54.230.53.71 80] Err http://apt.readynas.com/packages/readynasos/ 6.2.3/main g++-4.9 amd64 4.9.0-7 403 Forbidden [IP: 54.230.53.71 80] Err http://apt.readynas.com/packages/readynasos/ 6.2.3/main g++ amd64 4:4.9.0-4 403 Forbidden [IP: 54.230.53.71 80] Failed to fetch http://apt.readynas.com/packages/readynasos/dists/6.2.3/main/pool/g/gcc-4.9/libstdc++6_4.9.0-7_amd64.deb 403 Forbidden [IP: 54.230.53.71 80] Failed to fetch http://apt.readynas.com/packages/readynasos/dists/6.2.3/main/pool/g/gcc-4.9/libstdc++-4.9-dev_4.9.0-7_amd64.deb 403 Forbidden [IP: 54.230.53.71 80] Failed to fetch http://apt.readynas.com/packages/readynasos/dists/6.2.3/main/pool/g/gcc-4.9/g++-4.9_4.9.0-7_amd64.deb 403 Forbidden [IP: 54.230.53.71 80] Failed to fetch http://apt.readynas.com/packages/readynasos/dists/6.2.3/main/pool/g/gcc-defaults/g++_4.9.0-4_amd64.deb 403 Forbidden [IP: 54.230.53.71 80]Solved5.3KViews0likes4Comments
