data protection
1 TopicDo I need ReadyCLOUD?
I will soon be receiving a new ReadyNAS which will presumably run the current version of OS 6. I will be using the device for sharing confidential data within my local network, but I have no intention of setting up cloud access through the internet and - least of all - using a cloud service run by someone else, including Netgear. This also includes the backup of the data on my NAS, which I will perform only on locally attached, external drives. From whai I have seen in the internet, you use ReadyCLOUD to set up and administer your OS 6 ReadyNAS. I assume that this means that you have to identify yourself towards ReadyCLOUD, and that your login credentials will be stored 'somewhere'. Does this also imply that I will be at an increased risk of intrusion into my ReadyNAS through the internet? Which of the operations performed through the ReadyCLOUD interface will make my locally stored data accessible through the internet? Which may cause storage of local data on the ReadyCloud server? Finally: Do I need to use ReadyCLOUD at all? Are there alternative methods for setting up and administering my ReadyNAS? Of course, I do not want to be paranoid about data protection. But I neet do make sure who will have access to what, and where pttential gaps are. And there is so little 'substantial' information available about ReadyCLOUD and potential security issues ... Thank you, Andreas7.4KViews1like5Comments
