dns
12 TopicsDHCP Snooping Block DNS Packet
Hi, I've just encounter an issue with my GS724TPv2. As soon as I enabled the DHCP Snooping mode, I cant make dns resolving. Trusted Inferfaces are ok, and I retrieve an Ip from my dhcp server (which is the same as my dns server). I can ping, go to web servers (with their ips). If I turn off DHCP snooping mode, it works again (mac address validation didnts seem to have an impact), I can see my computer informations in the dynamic binding configuration screen. I have 3 724tp connected with LACP, i tried with one switch alone, no results I have DHCP snooping/filtering set up on my other switches (GS724T no POE) and I dont have this issue. If anyone has an idea (misconfiguration, bug,...) ? Thanks a lotSolved4.6KViews0likes8CommentsReadynas 314 - No internet connection
Would someone mind helping me to get the internet working on my NAS? I don't tend to access it very often when I'm away from home so I'm not sure exactly when the problem began. I want it to work so I get notifcations of any problems. It was working for at least a year. Causes could be: New Router, New Modem. My Telstra Smart modem is set to bridge mode. It's IP is 192.168.0.1 My Ubiquiti Security gateway router's IP is 192.168.1.1 I have an unmanaged switch. The local network and internet is working. I have had the smart modem for a month, purchased it so I was ready for NBN which was connected this week. The internet has never worked on the NAS when using this modem. This may or may not be the cause. The NAS is plugged into one of the spare ports on the unmanaged switch. My Nas Et0 is set to static, Eth1 is dynamic. Adaptor Eth0 had no DNS server in the IPV4 settings, Eth1 had 192.168.0.1 I've tried adding 8.8.8.8 to both adaptors. No cigar.Solved2.5KViews0likes2CommentsContinuing (worsening) problems with DNS resolution can be traced to the FVS336Gv2
Hi -- I'm having continued, and apparently worsening, problems on my network protected behind a FVS336Gv2 (v. 4.3.3-6) firewall. And it all has to do with DNS resolution. Any device behind the firewall trying to access the Internet will chug along just fine for a while, then suddenly start to exhibit all manner of problems related to DNS resolution. Most notably, Web browsers will start timing out with DNS errors. Then, suddenly, the problem will clear itself for a short while, before recurring. This has been an annoyance for some time, but recently the problem seems to have worsened significantly. The PCs all have DNS servers set up on their network interfaces. I have tried five different sets of DNS servers, including the servers from the ISP, OpenDNS, and Google. I have also tried setting up the FVS336Gv2 as a DNS proxy, and then trying it with proxying disabled. Whether or not it's set up in that way, the problem remains. On any of the affected PCs, if I run DNS Query Sniffer the problem is made quite obvious. As the PC tries to move around the Internet, DNS Query Sniffer shows every DNS request the PC makes. A cluster of several dozen DNS queries will show as responded to and resolved. Then several screenfuls of DNS queries will show as not being responded to. You can clearly see the progression on the part of the PC of querying the DNS1 server, not getting a response, querying the DNS2 server, not getting a response, querying the DNS3 server (the proxy, if it is set up), not getting a response, and so on. After a while of this, though, seemingly by magic the DNS queries start getting responses again. This is not a problem with a screwy PC. I can replicate this problem on any PC behind the firewall by running DNS Query Sniffer and checking its output. In case this was related to PC-based malware protection or firewalls, I've disabled these on the PCs and have seen no difference. The PCs in question are running either Symantec Endpoint Protection or Microsoft Defender on either WIndows 7 or 10. I also have a half-dozen Android devces that get caught in the same DNS trap while they're on the WLAN, which have no such problems if they're running on their cellular connections or on someone else's WLAN. Further, I can clearly see that it's the firewall causing the bottleneck if I reconfigure a PC to bypass the firewall and connect directly to the ISP's modem. With the firewall out of the way, DNS Query Sniffer shows almost every DNS query consistently resolved (with the odd miss here and there). The difference is dramatic. I can hammer the connection with DNS requests, as long as I'm hooked up directly to the ISP's gateway, and the PC won't miss a beat. But as soon as I connect the PC back behind the firewall, I can't get more than a few dozen DNS queries out before they start to get blocked (ignored, whatever). I have read a smattering of posts mentioning similar problems, and none seems to have a resolution. The culprit mentioned most often is the Block UDP Flood setting. This firewall had the setting switched off already; the DNS problem still happens. I switched the setting on and set the threshold to 999 (the highest it will allow), just to see if I saw a difference; it did not affect the DNS problem one bit. I switched it back off, as well as the Block TCP Flood setting. This had no effect. Otherwise, I have no problems with this firewall. It processes incoming traffic exactly as it's supposed to. It handles VPN connections properly. Outbound traffic from the PCs -- as long as it's not being encumbered by DNS resolution problems -- is OK. I don't know if this is an indication of a problem or not, but in trying to troubleshoot this problem, I've navigated the firewall's entire Web interface. And boy, is it slow. It can take the firewall several seconds at least (sometimes 20 seconds or more) to move from one page to the next. Is there a way to resolve this problem? Thanks CL1.8KViews0likes2CommentsReadyDrop.Netgear.com 50k DNS requests per day from ReadyNAS
Hi, I've recently noticed that I do get more than 50k request on my DNS server from ReadyDrop.netgear.com per day. This domain does not resolve anymore as : Effective September 1, 2016, NETGEAR will be terminating the ReadyNAS ReadyDROP service. For this reason, Netgear should remove it from their ReadyNas. 50k per day is quite a lot of useless DNS requests. As you can see below, the deamon is still running on Ver 6.8.0. root 5118 0.0 0.1 45036 4548 ? Ss Aug18 0:05 /usr/sbin/readydropd root 5170 0.0 0.0 12584 168 ? S Aug18 0:00 /opt/readydrop/bin/rdbrokerd root 5171 0.0 0.0 4336 1620 ? S Aug18 0:16 /bin/sh /opt/readydrop/bin/rdhook.sh I have the same issue with ReadyNAS 102.1.1KViews0likes0CommentsPreventing circumvention of OpenDNS with firewall rules
Hi, I am attempting to set up my FVS318Gv2 Firewall so it will block all DNS queries that are not from OpenDNS. I was using this article for reference. To do this, I created a list of outbound rules. The first two I have block all DNS for UDP and TCP. The next four allow DNS on OpenDNS IPs. According to the manual, this is the correct order "you should place the most strict rules at the top" My hope was that the allow rules would override the block rules. According to OpenDNS's Documentation: "The first rule trumps the second rule, so anything requests to OpenDNS are allowed but any DNS requests to any other IP are blocked." I've tried adding these in the reverse order and using port 53 instead of the built in services but whatever I try blocks all DNS requests. Am I adding these rules wrong? What else could I try? Here is a screenshot of my configuration (The block rules are disabled so people can use the internet, but were enabled for my setup) Thank you! -JoelSolved5.5KViews0likes5CommentsSRX5308 inter-VLAN issues
Hello! I have some issues with this routeur since a long time (relay DHCP not usuable, packet dropped, etc...) and each new firmware solve some problems, but not at all... 4 or 5 times by month, the DNS resolution on my subnet client won't reach the DNS server on a different subnet... The problem spend 3 to 5 mn to solve itself (?) and, during this time,I can't ping my Server subnet. I watch my DNS server log, but, no error noticed. On each client DNS, the event log said the serveur DNS is not reachable... Have you some ideas to solve this problem? Best regards. Fabrice.3.2KViews0likes6CommentsDNS Issue with FVS336gv2
I have 5 sites all with FVS336gv2. In our hub site we have a dhcp server and everything works fine. In our spoke sites the fvs336gv2 is running DHCP and in ipconfig /all lists a couple of our dns servers and the fvs336gv2 is listed as a third dns server. Is this normal? If not how do i get rid of it as a DNS server. When i try to join a new computer to our domain i have to manually set the dns servers then i move it back to auto config once joined.Solved4.7KViews0likes2CommentsFVS318G V2 DNS traffic getting through
Hi. I'm having an Issue with an FVS318G V2. I have only ping and port 8000 open for a specific address and all other traffic Is blocked but DNS requests are managing to get through. Is this even possible ? Could a virus/malware somehow pull this off and bypass the firewall ?3.4KViews0likes2CommentsRemote DNS for IPSec Tunnel Not Correct
I can establish a tunnel using the full VPN client to the FVS318N. Routing into the remote private LAN works as expected. However, DNS does not resolve to any of the names in the private LAN. How can I adjust the IPSec policy and/or VPN client settings to get the private LAN's DNS server working? Thanks!Solved4.2KViews0likes4CommentsDNS options for ReadyNAS?
I'm looking for some advice regarding setting up a DNS for my ReadyNAS. There is a very nice article on setting up a general website at http://kb.netgear.com/app/answers/detail/a_id/24829/~/readynas-os-6%3A-create-a-personal-webserver but the article ends port forwarding your external IP to your ReadyNAS. I own my domain name and would like bind my IP address to my domain name. There are a couple of apps available through OS6, does anyone have a recommendation? Has anyone done it before?
