docsis 3.1
2 TopicsOrbi WiFi System (RBK53) AC3000
I am considering purchasing the Orbi WiFi System (RBK53) AC3000 system along with the Netgear CM1000 docsis 3.1 cable modem. Is anyone running this setup? If so, have you experienced the random network drops that some have mentioned? Also, is there a limit to how many satellites can be added before a reduction in speed occurs? I want the router and 3 satellites provided that the addition of the 3rd satellite won't cause a performance drop. Thanks in advance for your help!SolvedDocsis 3.1 not available on R8000
So I love my Nighthawk to bits and cannot see having internet without it, bought it a couple of months ago for use on Vodafone NZ's cable network and it server me very well gor 101MB down and 10MB up, but now this morning I upgraded my line to Vodafone's new service FiberX which runs Docsis 3.1 and the R8000's firmware only currently supports Docsis 3.0 so now the router is dead to me it cannot go on the internet on Docsis 3.0 and now I have to rely on a crappy Huwai HG659 and although I get speeds of 942.91Mbps down and 99.74 Mbps up with a ping of 10ms the router does not have good wifio range in the house... When will a firmware upgrade be available to take the router from Dcosis 3.0 to Docsis 3.1?Solved7.7KViews0likes16Comments
