driver-related
1 TopicEvent 10400: A6200
Hello all, I have trawled Google, tried alternate drivers ranging from signed Netgear Beta drivers to BSOD-causing chipset manufacturer drivers. After hunting down several errors in my event log, one still persists among all else. Event 10400, NDIS The network interface "NETGEAR A6200 WiFi Adapter" has begun resetting. There will be a momentary disruption in network connectivity while the hardware resets. Reason: The network driver requested that it be reset. This network interface has reset 4909 time(s) since it was last initialized. This was merely leaving the wireless adapter attached to my computer overnight. The only way that I can fix the problem of intermittent connection issues is by unplugging the adapter and plugging the adapter back in, because it's a crapshoot whether the driver will restart on its own and regain connectivity. It's baffling that the device worked with Windows 7, then I update to Windows 10 and suddenly with a new driver it goes straight down the drain in terms of performance: - Disconnects at random - No networks shown - Can only remedy quickly by unplugging and reconnecting the device Any thoughts? Oh, you can get my DxDiag information here: https://www.dropbox.com/s/vbq5wdg48h1thqi/DxDiag.txt?dl=0 A copy of the event is here (device reset counter still rising): https://www.dropbox.com/s/qnk3xo4ni9zfq4f/Event%2010400.txt?dl=014KViews0likes20Comments
