ethernet failure
1 Topicupgrade from 6.8.1 to 6.9 disabled eth0,1,2,3
I upgraded my readynas 4220 from 6.8.1 to 6.9.0 and the three onboard ethernet ports are showing DHCP enabled in the gui but do not link to the switch. It seems as if they are administrativly disabled. I have tried factory reset and os reinstall as well as restoring the network configuration from a 4220 with the same configuration (as a matter of fact they are of exactly the same manufacturing run so the motherboards are identical) with no sucess. how can I get the system to rediscover (actually renable) the onboard ethernet ports?Solved1.7KViews0likes3Comments
