feature request
151 TopicsStardew Valley Multiplayer Not Connecting – Issue with Netgear Nighthawk RS700S?
Hi everyone, I’m running into an issue while trying to play Stardew Valley multiplayer on PC. The game either fails to connect with friends or stays stuck on the “Connecting...” screen indefinitely. I'm using a Netgear Nighthawk WiFi 7 Router RS700S (19Gbps), and I suspect there might be some configuration causing the issue — maybe NAT type or port restrictions. Here’s what I’ve already tried: Restarted the router and PC Turned off Windows Firewall temporarily Enabled UPnP in the RS700S settings Manually forwarded ports 24642 and 26120, which some Stardew guides recommend Despite all this, the game still can’t connect in multiplayer mode. Has anyone else experienced similar issues with the RS700S router? Are there any additional ports or settings I should be looking into to make Stardew Valley multiplayer work properly? Would really appreciate any advice! Thanks!The IGMP Snooping Static Router Port setting on GS108PEv3
The IGMP Snooping Static Router Port setting on GS105PE was originally not available on that model, but it was later added after a request to add it and was provided by updating the firmware. Our engineers will now review if it will be possible to add it on the GS108PEv3 and we need to log it as a request however we will not be able provide you an estimated time of release. We will have to wait and see it on the future firmware update of the product.16KViews2likes3CommentsFeature request to NetGear for Scheduled Shutdown.
This is a feature request to NetGear for Scheduled Shutdown. I know this has been mentioned quite a lot in other posts but nothing seems to have happened as a result, so I am renewing the request. Specifically, I want an alternative method to the existing scheduler. I wake my NAS by Wake-On-LAN whever someone logs into one of our domestic PCs. The NAS then stays on all day. Fine. But I want it to turn off at midnight. At the moment the only way to do this is to use the scheduler to turn ON the NAS at 11 p.m. for one hour. The NAS then turns itself off at midnight. This is OK if the NAS has been in use in the day so is still on, but unnecessary if no-one has used a P.C., when the NAS will have been off all day. Why turn it on at 11 p.m. just to turn it off again an hour later? Daft! So I want to schedule an OFF event at midnight without turning the NAS on beforehand. Of course if the NAS is off anyway, nothing happens. Another way forward is for someone to write an App to do it.2.7KViews0likes1CommentRN312 - hdd name of connected USB drives
I have problem with RN312, soft 6.2.0 When usb hdd is connected (back port, usb 3.0) system assign network name USB_HDD_1. After restart NAS (or force shutdown) even reconnect this usb drive (hot swap) network name of ubs share automaticly change to USB_HDD_8 (etc 5,11,14). In options: shares, external, settings of usb NAME cannot be changed (this option is greyed out) Question: Whether the name of usb hdd can be changed ? I would like to be able to change the name, as in the case of SATA drives. Because every time the network name of the disk is different and features USB backup disk do not work. SATA drives are functioning properly and topic not apply.2.9KViews0likes2CommentsEncryption, (FDE or equivalent)
I would like to request FDE or the equivalent in a RAID environment. My budget does not allow for an impenetrable computer room and my entire life, or at least part of it, is in one spot, on your device. AES would be best. I recently made the move to IBM from Dell due to the improved hardware level encryption and capacity options. Software or hardware encryption works. Maybe you can utilize existing drives that already have FDE. Within reason you can not put a price on security. Lastly, did I mention stable encryption. RG7.1KViews0likes19CommentsVirtualBox-Support
Hi, it would be fantastic to have a good VirtualBox support which keeps the installed VirtualBox software on the latest releases and offers the existing web UIs for administration. In addition it would be awesome to have the possibility to create a VM backup by using the existing backup infrastructure. Thanks, Campus
