firmware 6.4.0
1 TopicDownload backups does not work since firmware 6.4.0
I have a backup job that downloads files via FTP. It worked just fine until firmware 6.4.0 Now the backup job starts and after a while it stops with an error message: Backup Start Time: Sat Oct 24 2015 0:05:09 Backup Finish Time: Sat Oct 24 2015 0:49:18 Backup Status: Fail: connection cannot be established. Check the connection and authentication, if required. The FTP server is working properly - I checked this several times. Backup job works for about half an hour and then stops. My device is ReadyNAS 312 Could you please suggest a solution?4.3KViews0likes2Comments
