firmware releases
2 TopicsGS108EP / GS108EPP Firmware Version 2.0.0.4
Enhancements: Initial release Warnings: Do not use the NETGEAR Switch Discovery Tool (NSDT) to discover the device as it is no longer supported from firmware version 1.0.4.4. Use NETGEAR Discovery Tool (NDT) or the latest NETGEAR Insight App to discover the switch at the same subnet. If you disable HTTP and a problem occurs with the HTTPS certificate of the switch, you might not be able to access the device UI. In this case, you must reset the switch to factory default settings to regain access to the device UI. Download Link: https://www.downloads.netgear.com/files/GDC/GS108EP/GS108EP_GS108EPP_V2.0.0.4.zip Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.280Views0likes0CommentsGS105EP / GS105EPP Firmware Version 2.0.0.3
Enhancements: Initial release with production enhancements Warnings: Do not use the NETGEAR Switch Discovery Tool (NSDT) to discover the device as it is no longer supported from firmware version 1.0.1.4. Use NETGEAR Discovery Tool (NDT) or the latest NETGEAR Insight App to discover the switch in the same subnet. The firmware file for models GS105EP/GS105EPP is different from the file for model GS305EP. Ensure you download and install the correct firmware for your model. Known Issues: After you upgrade the firmware to version 1.0.0.7, the settings for the port LEDs on the Home page incorrectly change from ON to OFF, which is not the actual behavior of the physical port LEDs on the front panel. Workaround: To fix this issue, reset the switch to factory default settings. Download Link: https://www.downloads.netgear.com/files/GDC/GS105EP/GS105EP_GS105EPP_V2.0.0.3.zip Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.159Views0likes0Comments
