firmware
470 TopicsWP3000RP RANGE EXTENDER - NOT UPDATED SINCE PURCHASE SO WILL THE LATED DOWNLOAD VERSION FIX ALL PREV
I have had a WN3000RP range extender for about 3 years now and never downloaded any firmware changes. When I look up the downloads I fiond there are 5 available. Do I need to download and apply each in turn or will the latest one - 1.0.2.64 have all the updates from previous downloads?3.2KViews0likes2CommentsI bought Eax80 speed is capped at 90mbps
Does anyone know why when I installed my eax80 as an access point my Internet speed 400 mbps and after a couple of days is limited to 90mbps. I have tried downgraded to another version of the firmware also, I have tried to factory reset it. I have tried to contact customer service for Netgear but after three months that they don’t help you at all and every time I’m downgrade the firmware it starts at 400mbps and then after a couples of days goes back to being limited.1.5KViews0likes6CommentsEAX80 Performance issues
I’m seeing performance of this extender slowly degrade over a period of a month or so. Are there any known issues? After a factory reset, the extender works well. It has a few issues from time to time which are resolved by reboots, but eventually performance drastically drops and throughput is abysmally low, and no amount of rebooting the whole network will resolve it. Another factory reset and reconfigure and I’m back up and running for a month or so. EAX80 is in extender mode - 5Ghz only to router. Dedicated SSID Client SSID - dual 2.5Ghz & 5 GHz, same password. WiFi 6 enabled Everything else disabled to try and have stability Latest firmware Anybody with a similar experience or any ideas why the device degrades over time but fixed with factory resets. Never used to be this bad1.6KViews0likes5Commentsnetgear WN2000RPT firmware update - error firmware region! Any solution?
I have a WN2000RPT Wifi Range Extender which is currently running firmware version V1.0.0.24IC. As far as I can tell, it is a v1. According to the status panel, the region is "United States". I am trying to update the firmware. I see 2 files/versions, one for North America (WN2000RPT-V1.0.1.24NA.img) the other for elsewhere (WN2000RPT-V1.0.1.24.img). No matter which one I try, I get the a firmware region error. I have looked all over and can't find a solution. Any ideas? Thank you in advance for the assistance.2KViews0likes6Commentswn3000rp v1 Cant log in- website cant access, reset doesnt work, cant go to maintenance to update
wn3000rp v1 Cant log in- website cant access, reset doesnt work, cant go to maintenance to update https://www.netgear.com/support/product/wn3000rp http://192.168.1.250/ can open can choose language, then for second it shows next screen to choose network type and it opens https://mywifiext .net/ that doesnt connect On repeater theres only one light showing green Tried 3 times reset 10 and 15 seconds How to do some deep reset that will give update screen, or tell me link to maintenance update screen link so i can open it with http://192.168.1.250/ update or something like that Tried connecting with WPS to router and it worked- it made Wifiname_EXT but password doesnt work the same and still cant open https://my wifiext .net/617Views0likes0CommentsFirmware Update not found!
AC1900 WiFi Range Extender Hardware Version: EX7000 Firmware Version: V1.0.1.104_1.0.184 New update is available. Click here to start It never finds any update?????? Is this the most current update for this extender????? If it is, how so I turn off the new update notification????Solved1.6KViews0likes3Commentsex7300v2 cannot extend signal from Linksys EA9500V1
Hello everyone! router Linksys EA9500V1 2 wireless 2,4GHz and 5GHz Security mode: WPA2 Personal from: WPA2/WPA Mixed Personal WPA2 Enterprise WPA2/WPA Mixed Enterprise WEP I am trying to extend the signal by ex7300v2 (I have 2 pc) with the ANY settings: WPA2-PSK [AES] or WPA-PSK [TKIP] + WPA2-PSK [AES] but not successful: Connect any WiFi enabled device like you would connect them to your main network, using the credentials below. I tried also to change firmware to the last version V1.0.0.146 but same. I try to reset to the manufacture setting and again nothing. But I have D-link chipper extenders and they are connecting without any problem. (( Could you advise me, how to fix this problem? thanks!1.5KViews0likes6CommentsNighthawk EAX80 keeps shutting off
I have my Nighthawk EAX80 wifi extender connected to my router to pull a stronger signal throughout my house. I have noticed my extender keeps shutting off and not turning back on. I have factory reset it 3 times now and made sure the firmware is up to date, but it continues to power off. Any ideas as to why this is happening and how to fix it?595Views0likes0CommentsNighthawk X4 Wifi Mesh Extender AC2200 - Not able to connect to extender
A couple of months ago my extender stopped working. I have reset the extender, connected to the router, all lights are green, but the extender network is still not an option to connect. I try to use the app and it will not allow me to stay logged in long enough to do anything. It continues to log me out and give me a timed out error when I try to log in again. I had to delete and reinstall the app. It worked for about 10 minutes and is doing the same thing. When I try to set up via a browser, the site says I need to update my firmware, but I can't do that if I can't log in and stay logged in.956Views0likes1Comment
