flow control
1 TopicGS108v4 Flow Control
Can you tell me how the GS108v4 handles flow control? In the technical spec it says "IEEE 802.3x full-duplex flow control". When testing with a unmanaged switch that has flow-control and is connected to the GS108v4, it does not seem to consistently handle the pass through. Thanks,Solved9.9KViews0likes3Comments
