google drive
4 TopicsReadyNAS 6.7.1 and Google Drive Cloud Sync
Bidirectional sync with Google Drive Cloud does not seem to work. On the Bidirectional setting it only syncs from the NAS to Google Drive Cloud but not the other way round. I did some tests with all 3 sync modes: up / down / bidirectional. Even on the down settings it still does not sync from Google Drive Cloud to the NAS. Only the up mode works (NAS to Google Drive Cloud). On other posts/threads I've seen mention of setting the synchronisation check frequency but that does not appear anywhere. Can anyone help?14KViews0likes21CommentsSince Google Drive is enable, Disk spin-down does not work anymore
Hello, Since Google Drive sync is enabled on my readynas (RN314), the spin-down does not work anymore. After disable the sync, the spin-down is working again Did you experiment that ? the problem seems the same with dropbox sync. Thanks for your help Below some logs: google-drive.log -- Logs begin at Sat 2017-07-29 04:43:16 CEST, end at Sat 2017-09-16 10:19:55 CEST. -- Aug 24 21:33:15 READYNAS ng-csd[13398]: Reset the cache. SQL Statement invalid: SQL error or missing database: no such table: settings Aug 24 21:33:15 READYNAS ng-csd[13398]: W0824 21:33:15.702988 13398 FSCache.cpp:78] Reset the cache. SQL Statement invalid: SQL error or missing database: no such table: settings Aug 24 21:34:11 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = download_20150412_204649.jpeg. Extraction error: value already extracted Aug 24 21:34:11 READYNAS ng-csd[13398]: E0824 21:34:11.493209 13398 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = download_20150412_204649.jpeg. Extraction error: value already extracted Aug 24 21:34:11 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:11 READYNAS ng-csd[13398]: E0824 21:34:11.495277 13398 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = lille.jpg. Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: E0824 21:34:15.760298 13398 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = lille.jpg. Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: E0824 21:34:15.760414 13398 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = file.jpg. Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: E0824 21:34:19.790344 13442 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = file.jpg. Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: E0824 21:34:19.790473 13442 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: E0824 21:34:19.790591 13442 SyncUpsyncFile.cpp:359] Failed to update file. local file = /data/Drive_gdg/Google Photos/file.jpg, remote file = /Google Photos/file.jpg. INVALID_ARGUMENT: localPath or remotePath shall be file Aug 24 21:34:19 READYNAS ng-csd[13398]: Failed to update file. local file = /data/Drive_gdg/Google Photos/file.jpg, remote file = /Google Photos/file.jpg. INVALID_ARGUMENT: localPath or remotePath shall be file Aug 24 21:34:24 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = paris.jpg. Extraction error: value already extracted Aug 24 21:34:24 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:24 READYNAS ng-csd[13398]: E0824 21:34:24.035274 13398 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = paris.jpg. Extraction error: value already extracted Aug 24 21:34:24 READYNAS ng-csd[13398]: E0824 21:34:24.035425 13398 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.254144 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.256642 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.258381 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.259907 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.264672 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.266196 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.267810 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.269354 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted ... Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.280009 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.281559 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.283053 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.284624 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.286243 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 22:33:12 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 24 22:33:12 READYNAS ng-csd[13398]: E0824 22:33:12.522763 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 24 22:33:13 READYNAS ng-csd[13398]: Request failed, now waiting 776 ms before attempting again. Aug 24 22:33:13 READYNAS ng-csd[13398]: W0824 22:33:13.627715 13398 WSClient.cpp:128] Request failed, now waiting 776 ms before attempting again. Aug 24 23:33:22 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 24 23:33:22 READYNAS ng-csd[13398]: E0824 23:33:22.308737 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 24 23:33:23 READYNAS ng-csd[13398]: Request failed, now waiting 662 ms before attempting again. Aug 24 23:33:23 READYNAS ng-csd[13398]: W0824 23:33:23.406625 13398 WSClient.cpp:128] Request failed, now waiting 662 ms before attempting again. Aug 25 00:33:31 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 00:33:31 READYNAS ng-csd[13398]: E0825 00:33:31.477128 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 00:33:32 READYNAS ng-csd[13398]: Request failed, now waiting 390 ms before attempting again. Aug 25 00:33:32 READYNAS ng-csd[13398]: W0825 00:33:32.772245 13398 WSClient.cpp:128] Request failed, now waiting 390 ms before attempting again. Aug 25 01:33:39 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 01:33:39 READYNAS ng-csd[13398]: E0825 01:33:39.726773 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 01:33:40 READYNAS ng-csd[13398]: Request failed, now waiting 668 ms before attempting again. Aug 25 01:33:40 READYNAS ng-csd[13398]: W0825 01:33:40.841905 13398 WSClient.cpp:128] Request failed, now waiting 668 ms before attempting again. Aug 25 02:33:48 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 02:33:48 READYNAS ng-csd[13398]: E0825 02:33:48.316488 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 02:33:49 READYNAS ng-csd[13398]: Request failed, now waiting 585 ms before attempting again. Aug 25 02:33:49 READYNAS ng-csd[13398]: W0825 02:33:49.414007 13398 WSClient.cpp:128] Request failed, now waiting 585 ms before attempting again. Aug 25 03:33:57 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 03:33:57 READYNAS ng-csd[13398]: E0825 03:33:57.696195 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 03:33:58 READYNAS ng-csd[13398]: Request failed, now waiting 273 ms before attempting again. Aug 25 03:33:58 READYNAS ng-csd[13398]: W0825 03:33:58.788640 13398 WSClient.cpp:128] Request failed, now waiting 273 ms before attempting again. Aug 25 04:34:28 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 04:34:28 READYNAS ng-csd[13398]: E0825 04:34:28.741219 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 04:34:29 READYNAS ng-csd[13398]: Request failed, now waiting 769 ms before attempting again. Aug 25 04:34:29 READYNAS ng-csd[13398]: W0825 04:34:29.858224 13398 WSClient.cpp:128] Request failed, now waiting 769 ms before attempting again. spinndown.log Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 1 [sda,0:0:TOSHIBA_DT01ACA100:94Q8JWAFS:MS2OA750:7200] Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 2 [sdb,0:1:TOSHIBA_DT01ACA100:94M7XYBNS:MS2OA750:7200] Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 3 [sdc,0:2:TOSHIBA_DT01ACA100:94M8AU0FS:MS2OA750:7200] Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 4 [sdd,0:3:TOSHIBA_DT01ACA100:3311NN6NS:MS2OA750:7200] Aug 25 03:58:34 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 03:58:52 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:16. Aug 25 04:09:33 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:09:35 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:09:43 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:08. Aug 25 04:09:43 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:05. Aug 25 04:14:03 READYNAS noflushd[14387]: Spinning down disk 1 (/dev/sda). Aug 25 04:14:06 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 04:14:28 READYNAS noflushd[14387]: Spinning up disk 1 (/dev/sda) after 0:00:22. Aug 25 04:14:28 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:20. Aug 25 04:14:49 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:14:51 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:14:58 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:07. Aug 25 04:14:58 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:05. Aug 25 04:19:29 READYNAS noflushd[14387]: Spinning down disk 1 (/dev/sda). Aug 25 04:19:32 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 04:19:44 READYNAS noflushd[14387]: Spinning up disk 1 (/dev/sda) after 0:00:12. Aug 25 04:19:44 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:10. Aug 25 04:20:04 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:20:07 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:20:19 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:12. Aug 25 04:20:19 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:10. Aug 25 04:25:20 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:25:22 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:25:30 READYNAS noflushd[14387]: Spinning down disk 1 (/dev/sda). Aug 25 04:25:32 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 04:25:35 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:13. Aug 25 04:25:35 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:10. Aug 25 04:26:05 READYNAS noflushd[14387]: Spinning up disk 1 (/dev/sda) after 0:00:33. Aug 25 04:26:05 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:30. Aug 25 04:30:35 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:30:38 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:30:50 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:12. Aug 25 04:30:50 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:10.Solved3.2KViews0likes16CommentsGoogle Drive Beta Problems
So I just updated to 6.73 a couple days ago and noticed Google Drive Beta was an option for backup. I am already syncing using rclone to google drive so this was a nice feature upgrade for me. I enabled it but have not had much luck with it. Whenever I backup files to Google Drive it seems to get stuck in a loop on certain files. It uploades duplicates of the file until I stop google drive beta. I had 8 copies of the same file with the same name in my google drive. I was originally trying this with Amazon Drive enabled as well as Google Drive, but have since disabled Amazon and tried only Google Drive but the problem persisted. I have tried setting up Google drive in both bidirectional syncs and upload only mode and still does the same thing. It scans both the local disk and cloud drives correctly and only uploads new content. But when it loads the new content it just keeps loading the same file over and over. Would anyone be able to help? I can pull logs if necessary. Thanks, Dan EDIT: Also, another bug I noticed is you can't add more than one session at a time and hit apply, it comes back with an error in adding google drive session everytime.3.4KViews0likes4CommentsHow to backup to Google Drive, S3 etc using rclone
Hi, Im new to Netgear Community, in response to these two closed community posts: Developer Request: Full Cloud Sync Access via iClone & incond Backing up to your ReadyNAS I can confirm that rclone can (easily) be installed on ReadyNAS and successfully synced with Google Drive. While I havent deployed an official ReadyNAS developer app, and at this stage dont intend to, the setup took me under 10 minutes and can easily be replicated. Tested on ReadyNAS 104 firmware 6.6.1. Installation SSH onto the ReadyNAS Follow the rclone installation quickstart with the following changes: Substitute the AMD64 precompiled binary for ARM32, ie: curl -O https://downloads.rclone.org/rclone-current-linux-arm.zip Dont worry about copying the man file. As of version 6.6.1, ReadyNAS Linux doesn't come with man installed. Also, rclone --help is really thorough. Usage Follow the rclone for Google Drive doc. If you want to make it a supported Google APIs app, check this part of the rclone docs. Regards, Clive Typhon Solutions Pty Ltd4.6KViews4likes1Comment
