inter-vlan
2 TopicsS3300 inter-VLAN Routing Issue
I have just purchase an S3300-28X and S3300-52X and am getting to grips with all the features. Most features seem pretty straight forward so far, but I'm having real issues setting up inter-VLAN routing. I've been unsuccessfully banging my head against the wall for a few days now, so hopefully someone here will be able to shine some light on where I'm going wrong. I've factory-reset the S3300-28X and setup a simple configuration for testing: VLAN10 Interface IP: 10.0.10.1 Subnet Mask: 255.255.255.0 VLAN20 Interface IP: 10.0.20.1 Subnet Mask: 255.255.255.0 Port 1/g14 PVID: 10 VLAN Member: 10 VLAN Tag: None Port 1/g16 PVID: 20 VLAN Member: 20 VLAN Tag: None I initially setup the VLANs with the routing wizard, selecting the appropriate tags as untagged. After checking the PVID configuration I connected a workstation to each port with the following manual IP settings: Workstation (1/g14) IP Address: 10.0.10.123 Subnet Mask: 255.255.255.0 Default Gateway: 10.0.10.1 Workstation (1/g16) IP Address: 10.0.20.123 Subnet Mask: 255.255.255.0 Default Gateway: 10.0.20.1 Each workstation can ping default gateways on either VLAN, but the workstations cannot ping one-another. I feel like I've tried every possible setting in the PVID Configuration sections but nothing seems to work. So, could someone please suggest where I've gone wrong or what I should try next? Thanks!Solved5.1KViews0likes3CommentsSRX5308 inter-VLAN issues
Hello! I have some issues with this routeur since a long time (relay DHCP not usuable, packet dropped, etc...) and each new firmware solve some problems, but not at all... 4 or 5 times by month, the DNS resolution on my subnet client won't reach the DNS server on a different subnet... The problem spend 3 to 5 mn to solve itself (?) and, during this time,I can't ping my Server subnet. I watch my DNS server log, but, no error noticed. On each client DNS, the event log said the serveur DNS is not reachable... Have you some ideas to solve this problem? Best regards. Fabrice.3.3KViews0likes6Comments
