jumbo frames
1 TopicHow to enable Jumbo Frames on GS116Ev2?
Hello, I have a new GS116Ev2. It came with the latest firmware installed (v2.0.1.26). I am trying to enable Jumbo Frames. I can not find the setting either in the Web interface or in the ProSafe Plus Utility (v2.3.20). Ho do I set the Maximum Frame Size to 9216 (as I can do with cheaper Netgear products)? Thanks!Solved
