lan port configuration
1 TopicR7800 Not auto-negotiating speed correctly
I have a gig-unmanaged switch that when I plug my computer into it and the other end in the router it, it auto negotiated to 100mbps instead of 1000. every device on the planet allows you to set speed staticly, except this router.....unless I am missing something. Is there a way to for the lan port to 1000mbps?!?!?!?! so frustrating. I have test it directly and it works fine, and this gig switch ran at a gig on my old router.Solved9.2KViews0likes14Comments
