limited connectivity
1 TopicLimited or no connectivity
I have a wg121 usb wireless adapter which I have used on another desktop before with no problems. I just got a new used computer that has xp sp3 and I wanted to connect the adapter to it so I downloaded the newest driver, 2.0 but in the release notes it says "This release does not support WPA with NETGEAR's user interface." my router uses WPA so i downloaded an older version, 1.1 and installed it, As I installed it I got a window message stating it was not Windows verified but I installed it anyhow, Everything installed ok and it says it is connected to my router but no network shows so I can enter the username password which doesn't make sense because I had to enter it on my laptops...the icon on the taskbar that has the little monitor is green and both lights on the adaptor are lit but the network icon has a triangle with a ! in it and says no or limited connectivity, SOOOOOO aggrivated.Solved5.1KViews0likes2Comments
