link aggregation
1 TopicLink Aggregation with macOS
Hi, I've got two ethernet ports on my Mac mini and have bonded them together with the virtual interface. I've then plugged them both into my GS116Ev2. If I have LAG turned off the Ethernet bond from macOS connects just fine - if I turn LAG on, it disconnects and reports that my switch doesn't support link aggregation. What's going on here? Why are they working with LAG turned off, but not on? Are they even working with an aggregated connection with LAG turned off (is the Mac doing it instead?) should they work with it on?Solved
