macbook pro
1 TopicMacbook no UP status
Hi, new on here so apologies for any lack of knowledge. I have a MacBook Pro connected to my GS308EPP but it is not showing UP port status as is a connected router and NAS. It is showing AVAILABLE although I am able to see other devices on the LAN through the switch from the MacBook. The MacBook has a USB3 ethernet adaptor. Is this normal? Thanks.Solved
