network problem
1 TopicReadyNAS 312 cannot be accessed with LAN1+LAN2 at the same time after upgrade to FW 6.9.1
Dear community, we are running a ReadyNAS 312 connected to two networks (one via LAN1 with a fixed IP, and another via LAN2 with another fixed IP), using SMB. Until we upgraded to the current firmware version 6.9.1, everything went very smoothly. Since then, LAN2 cannot access the NAS anymore - only if we disconnect LAN1. As this is a very bad situation for us (only half of our people can work with the data on it), we really need to find a solution. Downgrading to 6.9.0 did not help. Downgrading to 6.7.1 (as before) is not recommended (maybe someone could give a hint if this is work a try anyway?). Any help or suggestion will be appreciated. Thanks in advance.1.2KViews0likes4Comments
