not listed
3 TopicsWeird IPv6 DHCP using SXR80 with SXS80
Hi, I found a weird behavior. After successfully connecting to WIFI, I get immediately a proper IPv4 address and all is fine. Looking forward to IPv6 (since more ISPs change to 6 only) I discovered a weird problem. A ping6 to the host is not possible. ifconfig shows only local address. Waiting a while I see a proper IPv6 address and everything works as expected. But the time I have to wait seems random to me (and maybe I trigger it by communicating in my network). This behavior is ONLY when using the Netgears as Access Point. LAN: no problem WLAN connection to my Internet Router (FritzBox 7590): no problem WLAN to SX80: the described problem Now, this is not only on my home - Same setup (NG as AP) at a different location: Exact Same behavior. So for me is clear: Some is blocked by NG devices. Any idea? (I ran out of it ;-) Thx RalfIs AX1800 compatible with AX1800 pro satellite?
Hi! I have an AX1800 mesh setup in my house. I need one more satellite but the AX1800 satellites are only sold in 2-packs or 3-packs. The 'Pro mini' satellites seem to be sold in single packs. Does anyone know if one of these satellites will work with the 'normal' AX1800 setup? Thanks!Cannot connect to the SXR30 router; primary WiFi is not working
Hi, Sorry if I'm posting this in the wrong support group. The primary WiFi on the SXR30 stopped working (Can't get an IP address). The Guest WiFi still works. But I need to use the primary WiFi. So my goal is to log into the device and reconfigure the primary WiFi network. Here is what I have done -- nothing worked so far: Rebooted to Modem and restarted the SXR30 router. 2) While connected to the Guest WiFI I tried to connect using ORBILOGIN.COM and ORBILOGIN.NET, as well as 192.168.1.1, and 10.0.0.1. The browser times out and can't connect 3) Connected my laptop using Ethernet cable to one of the LAN ports and tried connecting using the above login options. Nothing works. 4) Searched on the available WiFi networks for one with SSID ORBI92. No such network exists. 5) Use the ORBI app on my Android phone, but being on the guest WiFi it wouldn't allow me to connect. 6) Called Tech Support, but since I purchased the system in Feb 23, 2022 -- my tech support expired. The support tech also told me that due to security issues my system will completely stopped working unless i renew the support. I know that my ORBI Router and satellites have the latest firmware as of May 2025 since I was able to access the devices and have the firmware update. (I'm not sure how I access it then, LOL). My devices are registered on the Netgear site. I'm OK paying for the tech support, but I would think that this problem should not be so hard to solve. Any suggesting how to access the router and check why the primary WiFi isn't working? Thanks, Nahum
