not updating
1 TopicR8000 QOS Performance Optimization Database Not Updating
Hello, Whenever I try to update the Performance Optimization Database in the QoS, it says that it hasn't been updated, despite it from the end of 2015 (version 1.80,1.0.26 from 12/28/2015). My router has the most recent firmware update available, as shown in the picture. I had it set to automatically update before, so I didn't think about it too much. I updated my parents' R7000 to a newer firmware, and after I checked their QoS settings. They already had a newer version on the database, and when I hit the update button, their router was offered and even newer version (unfortunately, I don't have that version date or number notated). I started to research my issue when I came accross another thread about the same thing ( https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000-QOS-how-do-you-set-new-applications/m-p/1244609#M51975 ) and the official response from ElaineM was that "We will be providing regular updates on the QoS database on our routers with Dynamic QoS" and "We will inform the community if it becomes available" on April 6th. I can't find any more recent info on this problem. Is the R8000 getting any more QoS Performance Optimization Database updates? Why is it currently not pulling down the current updates? When can we expect a solution to this issue? I love this router to an unreasonable degree (it helped me fix most of my network issues, has amazing Wi-Fi range, and very rarely needs any tinkering or reboots if any issues do arise), and would like to keep all aspects of it updated. Thank you for your help.Solved21KViews4likes30Comments
