old ssid
1 TopicNew router with different SSID - can't change my Netgear extender's NETWORK_EXT NAME to match new ro
I've been using the extender and it works fine. But recently I got a new router with a different SSID and my extender's network name is still the OLDNETORK_EXT and I can't find a way to change it to match the NEWNETWORK_EXT name. The old network name will not connect to the internet. HOW DO I CHANGE THE NETWORK NAME ON THE EXTENDER to match that of the new router SSID? Should be a simple fix but all I keep finding is the exact same messages and instructions like in the manual on how to setup a wi fi connection and how easy it is and search for your network and ...etc.etc. You would think there would be some other answers for other problems than the simplest setup instructions.7KViews0likes7Comments
